#221
Old 11-06-2010, 09:31 PM
67'7F6'Bird's Avatar
We installed the ATI Flex Plate, we needed to enlarge the holes slightly and sanded of the powder coating where the bolts attach. Installed the PTC Torque Converter. Bolted the TH400 up and put it in place.
ID:	223622   Click image for larger version
ID:	223623   Click image for larger version
ID:	223624   Click image for larger version
ID:	223625   Click image for larger version
  #222
Old 11-06-2010, 09:34 PM
Some pictures showing how this intake and carb set-up would go through the Hood. Still considering the Northwind.
ID:	223629   Click image for larger version
ID:	223630   Click image for larger version
ID:	223631   Click image for larger version
  #223
Old 11-07-2010, 08:49 PM
Ed and I installed the Indian Adventures Headers. We had to file down each flange to make them true. Shimmed and Tightened the PTC 11 Inch Torque Converter.
ID:	223791   Click image for larger version
ID:	223792   Click image for larger version
  #224
Old 11-07-2010, 09:02 PM
Installed the MSD Distributor and Cut the Custom MSD wires to fit. Next is the exhaust.
ID:	223796   Click image for larger version
ID:	223797   Click image for larger version
  #225
Old 11-14-2010, 08:47 AM
Ram Air Restoration Ova; Exhaust install. I went with the 3.5 inch oval pipes to Spin Tech Mufflers into 3 inch round tail-pipes.
ID:	224501   Click image for larger version
ID:	224502   Click image for larger version
ID:	224503   Click image for larger version
ID:	224504   Click image for larger version
  #226
Old 11-14-2010, 08:52 AM
We mocked the exhaust up from the tail pipes forward, using ratchet straps, tie raps and our transmission jack. Initially we were unsure how the final fit would be, keep reading.
ID:	224506   Click image for larger version
ID:	224507   Click image for larger version
ID:	224508   Click image for larger version
ID:	224509   Click image for larger version
  #227
Old 11-14-2010, 09:07 AM
Adjusting height and centerline, making sure everything is level and square.
ID:	224514   Click image for larger version
ID:	224515   Click image for larger version
ID:	224517   Click image for larger version
ID:	224518   Click image for larger version
  #228
Old 11-14-2010, 09:13 AM
We used universal hangers in front of the differential, rear hangers need to be installed. It got too late and we decided to call it a night and weld all the seams today. Overall we are very happy with the fit. If only the tail pipes exited further back, but we can fix that. It is tight to the floor. The quality was very good, instructions cold have been more detailed. WE LIKE IT!!!!! And we would recommend it. Took a few hours to mock up, about a 2 day install if you want it to look the best. For sound, we will wait until next week.
ID:	224520   Click image for larger version
ID:	224521   Click image for larger version
  #229
Old 11-15-2010, 09:50 PM
mysticmissle's Avatar
looks nice guys. you have been very busy lately!
  #230
Old 11-16-2010, 10:49 PM
Thanks Jeff, Its been too long since she started. So were pushing forward, maybe this weekend we'll have the 455 running again.
  #231
Old 11-28-2010, 01:55 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Oil Pressure 60LBS. Water Temp 185 with a 185 Thermostat. 1050 Ultra was put on out of the box and with minor tuning ran well. We installed the Auto Meter Wide Band Air Fuel Gauge and it was a big help in tuning. The ignition is a combination of MSD 6AL, Timing Computer and Timing Control, so It needs a little more adjusting, which we'll do tomorrow.
The more Carb adjusting. SOUNDS AWESOME - This is me, Steve posting from EDS pc.
THANKS ED and Paul for all your Help getting this running!!!!!What a day!!!!!
  #232
Old 11-28-2010, 10:49 AM
RAIV-Z's Avatar
We would have been a bit further along with the tuning if the police didn’t drop by and kindly ask us to shut it down. Didn’t realize it was after midnight, time to put a clock in the garages.
  #233
Old 11-29-2010, 09:18 PM
Thanks to Jeff(SHAKER455) for coming over and tuning this Dominator. Got it running better, and with a little more work will make this carb run great.
ID:	226276   Click image for larger version
  #234
Old 12-11-2010, 12:19 AM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Talking OOOPPS
That's funny! I think many of us have done that before.
Nice build!
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
  #235
Old 12-11-2010, 06:47 PM
Here's "Foxie" just hanging out.
We installed the AED Throttle Assembly - It is a very nice piece. Worked perfect with the LOKAR Throttle Cable and LOKAR Pedal Assembly. I can finally REV the engine with my foot.
Also got the Aluminum 4 Core Radiator, supposed to be able to keep cool a 1000 HP engine, I think I'm more than covered there. Also got my 16" K&N Drop Base Filter.
ID:	227696   Click image for larger version
ID:	227697   Click image for larger version
ID:	227698   Click image for larger version
ID:	227699   Click image for larger version
  #236
Old 12-11-2010, 07:06 PM
Here is the Midnight Series Lokar Pedal Assembly.
Gauges are in and Working.
B&M Shifter installed and functional.
And Brighter Exhaust Pictures.
Yes, I will be getting a NEW DRIVE-SHAFT, I'm looking at Denny's or Strange.
ID:	227707   Click image for larger version
ID:	227709   Click image for larger version
ID:	227710   Click image for larger version
ID:	227711   Click image for larger version
  #237
Old 01-01-2011, 06:50 PM
Ed and I started the install of the "American AutoWire Classic Update Wiring Harness."
We got the Dash Harness installed and called it a night. So far Very nice Kit.
Steve
  #238
Old 03-19-2011, 10:34 AM
I received my SNOW PERFORMANCE METHANOL INJECTION KIT this week. Hoping this helps to avert Detonation. The kit was well packaged. I did find another company "Alcohol Injection Systems" which has a much better tank for the Methanol/water Mix, It looks like a fuel cell, I may get the tank from them, as the Pumps are the same.
  #239
Old 08-18-2011, 10:27 PM
SUPER 400 HOOD and Cowl panel almost ready to ship. Retro-Sound Radio to be delivered tomorrow.
Name:	SUPER 400 HOOD.jpg
ID:	253916   Click image for larger version
Name:	HOOD AND COWL.jpg
  #240
Old 08-19-2011, 04:28 PM
Region Warrior's Avatar
Who's make'n the Super 400 again?
