Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
Thanks guys,
All of the threads looked fine so they were cleaned and reused. And now I know! Tony |
No but they can be over torqued and stretched. They are nothing special that I am aware of.
69 GTO Judge 69 Firebird Trans Am clone 76 Trans Am 400 4spd. 06 GTO M6 18's red/red - 1 OF 188. 09.5 G8 GT Stryker blue met. premium with sport pkg. Last edited by goatnut; 01-10-2011 at 05:10 PM. Reason: spelling?? |
After twenty five years of building Pontiac motors I have NEVER seen a Pontiac head bolt stretch. EVER. Can they? I am no metallurgist but I assume they could, under the right circumstances... Remember, newer cars are usually sealing aluminum heads to a cast block, the two different materials expand and contract at different rates, these motors have a much harder time keeping the heads sealed properly. One way they try to keep the seal is by using a more "elastic" bolt that keeps the pressure on the gasket throughout the heat cycle. These bolts fatigue much more quickly than the bolts used on older cars. Alot of times these bolts are considered a one time use item. I assume you have ARP main studs, rod bolts, intake bolts, flywheel bolts, cam and crank bolts, etc.? Because they all could be overtorqued and stretched as well.
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! Last edited by PaulatFast; 01-11-2011 at 10:39 AM. Reason: added a smiley face to show I was just ribbin' |
Yes sir all new ARP bolts/fasteners.
![]() I to have been wrenching and building engines for over 25yrs and yes most all are everyday driver type cars new stuff. You got me on the poncho experience I have only put together a few. The differance between my build and probably most on this board was more reliablilty than originallity. I have seen more than enough failures due to reuseing old balancers and such. Like you I am not here to argue just personal preference.
69 GTO Judge 69 Firebird Trans Am clone 76 Trans Am 400 4spd. 06 GTO M6 18's red/red - 1 OF 188. 09.5 G8 GT Stryker blue met. premium with sport pkg. |
