Old 12-08-2010, 03:00 AM
pontiac_banshee's Avatar
pontiac_banshee pontiac_banshee is offline
Default Help - Need Tach Picture
Need a dead on straight picture of the tach from the underside of the hood. Need reference for problem I had with shop who decided to bypass the instructions and drilled the hole to large. Need it to reference how it should look based on how mine looks.
Would really appreciate a few shots if you could.
Old 12-28-2010, 04:53 PM
ak409ak ak409ak is offline
Are you still looking for pictures of the tach, from under the hood. I have a 67 bird that I can take some pictures of tonight.
ak409ak
Old 12-29-2010, 02:26 PM
Default Yes
Need some from underside straight on showing the hole cutout and holes for bolts going through.
Old 12-29-2010, 02:47 PM
I'll take them tonight. Where do you want them emailed to? I also have a template for the holes.
Old 12-29-2010, 04:09 PM
bobzdar bobzdar is offline
I can also take a pic if necessary.
Old 12-29-2010, 04:18 PM
[email protected]
I have a template to. The problem is the guy (shop) that did mine didnt hvae the correct hole saw so instead of asking me if he could buy one he used a 1/4" larger saw. Yah, he had the instructions from the manufacturer but now I am stuck so want to see how bad it is.
Old 12-29-2010, 04:27 PM
I'll take them tonight and send you an email. I'm in Colorado so it may be later where your at.
ak409ak
Old 12-29-2010, 11:40 PM
I here's the photo. I also sent it to your email.
ID:	229197   Click image for larger version
Old 12-30-2010, 09:18 AM
East East is offline
Default Actually...
I have a factory hood that was equipped with a hood tach and the hole was not centered between the inner frame opening. The frame has a scallop where the hole through the hood skin was made.
About 25 years ago, I removed the 400 skin and replaced it with a fiberglass Trans Am skin because I wanted a 1969 Trans Am hood on the car. My idea seemed to be a good one as they produce Trans Am hoods with steel frames these days for $900.
This post should be in the thread for car blunders/how I fukked up my car. Geez, I can't even begin to count how many times I regret the removal/disposal of the factory parts off of my car.
ID:	229209   Click image for larger version
ID:	229210   Click image for larger version
Old 12-30-2010, 10:33 AM
RA1John RA1John is offline
Some reference info for the '67-'68 (early, tall style) Hood Tach location...
ID:	229216   Click image for larger version
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 12-30-2010, 10:46 AM
Thats good info. The problem with some of this stuff, is what is really really correct. I know the factory may have spec'd it one way, but did all the plants do it that way. In some cases the hood tachs were a dealer add on I've been told. I'll use this to check mind, but if it's a little different, it will stay that way.
Old 12-30-2010, 11:41 AM
Default RA1John's diagram and picture looks right on the money
If you compare the location in my pictures with RA1John's pictures, the hole is exactly the same. It would seem easier to place the hole within the frame opening but they didn't. Perhaps the persons responsible at the factory needed it to be closer to the driver so it was placed where the frame required the scallop cut. It may have even been a wiring configuration where the harness only reached to that location.
It's your car and you can do whatever you wish to do. The worse thing that can happen is some self righteous Pontiac know-it-all plick will lambast you for having it mounted incorrectly due to the original location being studied in a wind tunnel to allow the tach housing from interupting the slip stream or from being blown off the hood. They weren't able to keep the moisture out though.
Old 12-30-2010, 12:04 PM
Oh well it is what it is. If it's later that I feel I really need to do, I'll have to get another hood, for it what it is.
Old 12-30-2010, 12:35 PM
FWIW...
The pix/drawing I posted above is from an original, untampered with '68 Firebird
(early production) that came from the factory with the 1st style (tall) Hood Tach (as also used on the '67s). Have the same drawing/pix for the 2nd style (short) Hood Tach on a '68 Firebird Hood and the hole size, location is different.
John
John 14:6
Semper Fi
Old 12-30-2010, 12:48 PM
My pictures were from a 67 tall tach, 1st week of April build (I think this would be considered early, isn't it), but mine may have been a dealer add on.
Old 12-30-2010, 02:09 PM
I have a '67 with factory hood tach, will take a pic when I get home just for comparisons sake.
Old 12-31-2010, 02:15 PM
Here are pics, PHS docs say factory hood tach.
ID:	229363   Click image for larger version
Old 01-08-2011, 10:49 AM
Hey guys,
I was checking over my doc, Car Billing History and the Options & Accessories List that I receive from PHS sometime ago, these doc state that I do have a factory mounted hood tach. It's stated as 444 in these doc (GRP 062, rally gauge cluster & hood mounted tach, COL 444). I know that it does not match the template that we all have for the position of the tach. So what gives??? I'm the third owner and have own it since 1992 and I know the privious the second owner who bought it in 1980. Any comments?
ak409ak
Old 01-08-2011, 08:58 PM
wovenweb's Avatar
wovenweb wovenweb is offline
Originally Posted by RA1John View Post
FWIW...
Can you post the second drawing? I have a May car which I think the 2nd style would be correct for(owner installed option).
Old 01-11-2011, 12:37 PM
Originally Posted by ak409ak View Post
Hey guys,
ak409ak
No idea, could just be production line variance or the hood could have been replaced at some point.
