Old 02-27-2011, 02:23 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
Try this it might be what you need? T#990411
http://www.restorationspecialties.co...og%20ebook.pdf
Scott
If you always do what you always did
You always get what you always got
Old 02-27-2011, 02:31 AM
Forgot page # it is page 95.
Scott
Old 02-27-2011, 10:15 AM
hawk36 hawk36 is offline
Is just the ticket. Thanks much.
Old 02-27-2011, 02:43 PM
Old Goat 67's Avatar
Guess I'm going to have to try one, I will call them tomorrow.
Charles
Old 02-27-2011, 03:58 PM
GT182's Avatar
GT182 GT182 is offline
I got one from PY tho it's not quite the same as the original... but it works. Has 3 holes and is a 1-1/4" grommet. Page 38 Pt# RPE222A.
Look on Page 99 too in the Restoration Specialties catalog. It's another GM firewall grommet, and is like the one I'm using. Hey, it'll do in a pinch if you need one and don't mind it not being absolutely original. Charles... don't look. LOL
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-27-2011, 06:44 PM
Yes, but with AC in 67 we need four holes. Three vacuum lines and wiring harness.
My old one could be reused, but it would be nice to have a new one.
Charles
Old 02-28-2011, 08:46 AM
1967SC's Avatar
1967SC 1967SC is offline
Default 4 Hole Grommet
I got one from Corvette Central.
It has four holes,their p/n is 303040.They list it for '68-74.
It fits a little loose,but it's the best one that I have found.
The holes for the wires might be a little tight,but you should be able to get them through.
Old 03-08-2011, 10:12 PM
Well, just recieved part # 990411 from Restoration Specialties. TOO SMALL. Do not order it.
I guess its going back.
Charles
Old 03-09-2011, 01:00 PM
This looks like it is the correct size, and I was going to get one, but they want $6 for the grommet and $9 to ship!
http://www.parts123.com/parts123/yb....Z5Z5Z50000050D
No way, unless we can do a group purchase on these.
If not, my old one will be siliconed and used again.
Charles
Name:	Corvette Central AC Grommet order.jpg
Old 03-09-2011, 01:16 PM
I just called Stacey and told her, "PLEASE get these for us".
Old 03-09-2011, 01:22 PM
SD421's Avatar
SD421 SD421 is offline
I was able to gt a very similar firewall pad rubber not plastic grommet from them as well. It wasnt too long like the ones PY & Ames sell as "correct" for our Goats. In fact that grommet they call "correct" is actually for the Firebird firewall pad.
FWIW,
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
