Old 03-03-2011, 12:45 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Not usually. IIRC, the pitman arm is keyed so you can only put it on one way.
The easy way to fix it is to loosen up the bolts (2 ea.) on the tie rod sleeves and turn both of them equal amounts in the same direction. Go about 1/2 turn at a time. That will re-center the wheel.
Edit:
Nice car, BTW!!!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
