Old 04-27-2011, 11:39 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Just from what I can see:
SJ package - 428 etc
Leather
p/seat
p/windows
AM-FM
A/C - ice cold
Rallys
tach and gauges
wood wheel
tilt wheel
vinyl top
I need to stab a jack under the rear and see if it has posi. The car does need a couple of things such as... upper control arm bushings, a set of shocks, valve cover gaskets and a detail.
What a nice car! Very clean and original. Most '69 SJ's had posi, it was mandatory with the 428 engine at some point during the production year.
I see these options as well...
Remote mirror
Auto Temp Control
Power (vacuum) door locks
I'll guess that it has a power trunk release too? I see that it has the 400 type (small snorkel) air cleaner and black lid... I wonder if that's been on the car since new?
Old 04-28-2011, 11:56 AM
Remote mirror
Auto Temp Control
Good eye on the auto temp... I forgot about that one.
I need to do a couple of things to the car before I take it on any road trips.
Old 04-28-2011, 12:41 PM
mrrat1 mrrat1 is offline
I like the color combo.........you make any wine? I see the vines, nice set-up you have there, and the injuns look good all in a row!! DK
Old 04-28-2011, 01:23 PM
Sounds great! I will let you know of any upcoming car shows. Kind of short notice, but there is a nice event in old town Fair Oaks this Sunday that I've been to a few times.
There is a Pontiac show this weekend in Madera.
"The Central Valley Classic Car Show is Coming on April 30, 2011!
This great car show is open to all Pontiacs, Buicks, Oldsmobiles, Cadillacs and GMC Trucks!
Where:
Madera County Courthouse Park; Yosemite Ave. at Gateway Dr. (Highway 145) in downtown Madera."
http://www.pontiacsofcentralcalifornia.org/
Old 04-28-2011, 01:26 PM
Thanks!
No... I don't make wine. Thats someone elses property across the road.
Old 04-28-2011, 02:49 PM
428ho4spd's Avatar
Where:
That's a nice event, went to that a few years ago with a friend here in town in his '71 GP.
Old 04-28-2011, 08:10 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
very nice!
Old 04-28-2011, 08:12 PM
We took the '67 there last year and had a great time.... Doesn't look like we're gonna make it this year though.
Went to take the '69 for a little drive today and it didn't even make it out of the garage LOL... It fired up and went to high idle like its supposed to.... I let it run for a couple of minutes and kicked it down and about 30 seconds later it died... like it ran out of fuel... tried to restart with no luck ... threw a couple of gallons in the tank tried to restart with no luck.... popped the hood to prime the carb... and noticed something leaking.... and its coolant!!!! I expected it to be fuel because its coming from around the fuel pump.... Sooo I shut the hood and jumped in the GTO and did what I had to do.... I should be down there investigating instead of sitting here typing this.... I need to get off my lazy ass mow the lawn and fix my car LOL...
Old 04-28-2011, 09:04 PM
Arnold Wiebe Buick Pontiac GMC Inc?
Its a black plate car that was bought new in Visalia... still has the original plate frames and the original windshield with a 1974 California inspection sticker.
Old 04-28-2011, 10:23 PM
Thats the place.
Old 04-28-2011, 10:53 PM
428ho4spd's Avatar
Maybe we can plan on that show next year.
That's really strange? Cant imagine what would be leaking near the fuel pump other than a coolant passage inside the timing cover. I wonder if the timing chain let go and did something? Pull the dist cap and check for rotation while cranking.
Old 04-29-2011, 01:49 AM
That sounds good.
Yesterday I had the hood up nosing around... and it doesn't look like the timing has ever been off. I know the timing chains usually let go around 100-120k... and this thing has got 130k on it. I got my lawn mowed... but haven't had a chance to take a closer look at the car yet.
Old 04-29-2011, 10:01 PM
428ho4spd's Avatar
At 130K I cant imagine the original plastic tooth cam gear would have lasted that long, but its possible. My brother's '70 400 went over 90K before it let go.
Old 04-30-2011, 01:35 AM
I'm gonna check it out tomorrow.
Old 04-30-2011, 05:12 PM
It ran out of gas... I guess the gas gauge isn't real accurate as it was reading an 1/8th of a tank. Its not leaking coolant at this time but does have an original heater hose that I'm gonna raplace.
Old 04-30-2011, 09:07 PM
GpFreak's Avatar
GpFreak GpFreak is offline
That's funny, my '69 and '70 both run out around 1/8 tank, found this out the hard way.
Steve Naresky
Old 05-01-2011, 12:33 AM
428ho4spd's Avatar
LOL... Well, that's a good reason it quit running! Maybe after a couple of fill-ups and $200 later it will straighten itself out.
  #38
Old 05-01-2011, 01:24 AM
After I put some gas in it ... I took it for a good highway run and its gonna need to have the radiator recored... It tachs 3 grand at 75.... so I'm guessing 3.23's.
  #39
Old 05-01-2011, 07:38 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Neat car. I like it a lot. Very similiar to my SJ 370/auto but I have green vinyl.
I just spent a few bucks on exhaust, cooling, motor mounts, trans rebuild and gas sender, plus a few other things. (My pesky front main leak as actually FUEL PUMP coming loose...go figure) Just got the car out yesterday now that the roads are clear of salt and the usual dirt of winter. Last thing to fix is the hi idle not coming off quick enough.
3.23 very common on SJ. Just change the ac pulley bearing or take the belt off before a lot of highway running. We never seem to need ac very much in the mountains, guess that depends on how much you plan to use it. I finally got the tools to change the compressor bearing out, did one, fun task.
You may have to spend about $3k on it for all the stupid little stuff to get it reliable. My only suggestion is to replace just the rear springs. Will give it a real nice rake but may drag exhaust.
  #40
Old 05-01-2011, 11:31 AM
My 68 GTO does the same thing, the 69 G/P hasn't yet but I try not to run it that low......
former." --Albert Einstein
- Winston Churchill
