#1201
Oh most importantly...69 Firebird 4-speed console!!!!! This is a MUCH needed item I know sevarl guys that need one.
Anything for the 61/62 B bodies.
#1203
Im tired of seeing original ones go on ebay for $500+
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#1204
Complete dash for 69 GTO
'Ram Air' scoop inserts in metal, not plastic. Bear |
#1205
Repro fuel tank for 71-72 grand prix's would be sweet.
#1206
I spoke to several mfg's on the GP tank. Each did not sound overly enthusiastic, but I will keep trying. Each year I say something to those guys. GP Mike
#1207
Manual Shift Linkage Swivel Trunnion for the 64-66 4 speeds.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#1208
repro steel hood for 70-76 Trans am. They are making hoods for 77-81's already???? why skip the older cars???
#1209
Door shells for 70 GTO
#1210
Door shells for 70 GTO.
#1211
in the works! No specific date yet but expect to see it available in the next 12-15 months.
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
#1212
In stock. RFR56A
#1213
Unitized wire looms.....PLEASE SOMEONE!
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match 1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match 1999 T/A Navy Blue 60k mi....babied ![]() 1968 442-gone but not forgotten "Oh,you can think about it,.....but don't do it!" Sheriff Bufford T.Justice |
#1214
'65-6 big car battery trays. Yes, I am jamming the ballot box.
'66 2+2 side trim and retainer clips, quarter panel 2+2 emblems. Cost of NOS is unreal. '65-6 Coupe / GP gas tanks. Preferably the kind that make their own premium! |
#1215
About time to ask again.......
75-81 Firebird full rear quarter panels - Please! I dont wanna buy another "good" used quarter section from CA for $1000 only to find its been in a crash in a previous life. New metal Please! Full length frame rails with the front spring hanger area for 74-81 Heck....ANY new sheet metal to restore a 1975 bird would be good for me.
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
#1216
Okay, from the top:
Power Steering Pullies for 67-72, and G-Body Pontiacs. Perhaps the PS & Alt bracket kits if they are not already available. Rear Disc Brake Caliper Brackets for 67-72 Rears, where the Brackets accept 10&12-Bolts, and the Strange Dana60 Flange, Then accept either GM Rear Calipers 79, 86, or 95 Lincoln 8.8rear calipers (because they are BETTER with the mini-drum EMERG Brake). And Rear Rotors: 79 T/A, 86 T/A, Lincoln 8.8rear rotors. An EMERG Brake cable "crimped-to-length" to support ANY Emerg Brake cable application. (I need). A driveshaft Safety Loop that anchors to the Seat Belt Bolt weld-nuts (Kit would include a pair of longer seat-belt anchor bolts so the Loop can be nutted-on. Lincoln-style 8.8 Rear Yoke kits for 10&12 Bolts rears to replace the U-Bolt design, GTO size & 1350 size U-Joint. Front & Rear Shocks with external knobs/setscrew for Up-jounce adjust, & down-jounce adjust. Ram Air III hood stickers Aluminum Rear Bumper brackets for 68 GTO Aluminum Front Bumper brackets for 68-72 GTO 'glass GTO Front nose with actual mounting capability-to-fender-front-holes & Rad Support, to Reliably replace Endura. Aluminum Front Upper Control Arms that are stock looking, with upper mount bar, either bushed-or-bearing. Aluminum AC Compressor Mount Bracket-to-Head. Aluminum Radiator supports for 68-72 Aluminum or black plastic Front wheel wells for 68-72. Aluminum window crank kits to replace the heavy steel parts in Doors&Quarters. Aluminum TH400 parts: 1-2 Servo cover, Center-Support, Front Pump Cover, Pump Rear cover too, ValveBody, perhaps the parts that carry HP&TQ. Pair of Billet Rear Lower Control Arms (seen a pair for a Honda at $200, that are 2" shy of fitting the GTO). |
#1217
67 LEMANS GRILLS,TAIL LIGHTS TAIL LIGHT BEZELS AND EMBLEM BETWEEN TAIL LIGHTS
#1218
A bolt in affordable roll bar for 2nd gen f bodies.
79 Pontiac Trans Am |
#1219
71 GTO Grill insert rings (chrome) These go around the mesh.
"Buffy" 1969 Firebird vert (mine) Not a clean one owner. Born Carousel Red, 350 2bbl, A/T, P/S, P/B, A/C. Now, Primer gray. Will have a 400, 5 sp, P/S, P/B, A/C, Black with carousel red pin stripes. |
#1220
67-69 Firebird th400 dipstick & tube.
Looking for years for one and nowhere to be found
Restoration Album: http://s262.photobucket.com/albums/ii106/colorado68/ |
