#141
Old 06-02-2011, 04:04 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Kieth, my Lemans is a 63 as well. The interior is Saddle, with AC, PS, PB and console. It has a 69 400 motor and a 2BL rochester. I put RA3 exhaust manifolds on it. Should make a good driver.
Gary, I got my 400 cfm AFB from Carb King. 573) 392-7378 Nice guy and a PYer.
fasteddy
  #142
Old 06-02-2011, 04:58 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Originally Posted by fasteddy View Post
Drove it to work today. Been a fun project. 195, 4bbl, high compression, 3 speed, original body color and interior. Now to get my Cameo White Lemans finished.
That is a sweet ride Steve!!
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
  #143
Old 06-20-2011, 07:33 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Making some progress on my 63 Lemans. The 68 400 engine and 700R4 trans are in and running. The bum part is that I have to tow it 3 hours each way (across the desert) to the Bowtie Overdrive trans shop in Hesperia, CA because the trans pressures are a little low! After that the engine & trans will come back out and its finally off to the paint shop.
ID:	247503   Click image for larger version
ID:	247504   Click image for larger version
  #144
Old 06-20-2011, 09:39 PM
ronk455's Avatar
ronk455 ronk455 is offline
Thumbs up Maiden voyage tonight!
Well after almost a year of owning my 62, I was able to take it down the road tonight. As far as I know the car hasn't moved under it's own power for almost 4 years. I received it last July 4th weekend. Been working on it ever since. Neighbors looked at me kinda funny tonight. I was sitting on the floorpan, no front or back glass in it. It started, stopped, shifted and turned. Smokes a bunch, exhaust rattles like crazy, but I don't care right now. When I purchased the car I wasn't even sure if the motor was ok. Now all I gotta do is get the interior finished before Norwalk. I owe many people on this site a great big THANKS, for all of the help with this car!
Ron
ID:	247536   Click image for larger version
ID:	247537   Click image for larger version
ID:	247538   Click image for larger version
  #145
Old 06-21-2011, 01:44 AM
R 70 Judge's Avatar
Rack and pinion going together. It's all welded up now. K member is being sent off for powder coating. If anyone wants to convert let me know and I can tell you what you need. The rack is saving a ton of weight off the front of the car.
Couple pics of the 20 gallon fuel cell mounted as well. It is mounted on two 2" wide x 1/4" thick steel straps that is welded to the front and rear of the trunk. There are also braces under the 2" x 1/4" rails for support. The hole for the sump is small and unobtrusive. I'm very happy with how it's coming out.
ID:	247562   Click image for larger version
ID:	247563   Click image for larger version
ID:	247564   Click image for larger version
ID:	247565   Click image for larger version
James
1970 Trans Am
  #146
Old 06-21-2011, 01:51 AM
ahnuld's Avatar
ahnuld ahnuld is offline
looks really good. keep the pics coming, one day i am also going to change my front end.
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
  #147
Old 06-21-2011, 10:57 AM
GaryK's Avatar
GaryK GaryK is offline
Ron
Hi Ron,
Car looks great!! Have not seen too many in your color combo either!! I got my carpet yesterday will post pictures on the other thread. I am real happy with it.
Gary
  #148
Old 06-21-2011, 07:27 PM
Radman's Avatar
Radman Radman is offline
Ron
Ron, very nice job. One note, look for a factory style oil fill breather cap. I see the oil on your valve cover. That is because most of the new replacement caps do not have the tube on the inside of the cap. The factory cap has a tube that goes up a little over 1/4 inch inside the cap. That stops the oil from splashing up inside the cap, then running out of the breather holes.
  #149
Old 06-22-2011, 05:13 PM
Radman's Avatar
Default Breatber cap info.
I had a PM asking about the breather cap comment that I made. I am sure more than one person has this issue. I had the oil drip on the valve cover until I noticed something while working with an original untouched for years engine. The old breather cap is taller than most of the one's you can find today. The distance from the gasket to the bottom of the breather cap on the old style is 3/8 of an inch. The same area of the new style is only 3/16th of an inch. That extra 3/16 distance is enough to keep oil from running out of the breather when the engine is running. The first picture is my engine after 100 miles, some of it at 70MPH, most at 55MPH on a 2 lane road. I did not clean the engine at all. The second picture is an old and new breather cap side by side. The black one is original from a 61 engine. The chrome one is aftermarket purchased 3 years ago. Look close and I think you can see the difference.
ID:	247722   Click image for larger version
  #150
Old 06-22-2011, 05:45 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Any car with a road draft tube will drip oil onto the valve cover. Thats a given. If you have the stock breather cap, it will be minimal. If you have a PCV valve system on your motor, you should have no oil leakage. This is assuming your motor is in decent shape & does not have excessive blow by. Every time I am under the hood checking the oil, water,etc. I allways wipe the area around the breather cap. Just a habit I guess. The current build has about 200K on it. Several oil leaks but the plugs come out perfectly clean, so it will run some more.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #151
Old 07-24-2011, 10:17 PM
blueghoast's Avatar
Default 62-Tempest
Well mines finally back on it's wheels but i'm way behind on prgress.
Back problems brought me to a holt. I'll make Norwalk just won't
Have the car there. I'll try and get some more pics up soon.
  #152
Old 07-25-2011, 01:22 AM
R 70 Judge's Avatar
Finally sitting on a 4 wheels again!
ID:	251269   Click image for larger version
ID:	251270   Click image for larger version
ID:	251271   Click image for larger version
ID:	251272   Click image for larger version
James
1970 Trans Am
  #153
Old 07-25-2011, 01:28 AM
R 70 Judge's Avatar
few more
ID:	251274   Click image for larger version
ID:	251276   Click image for larger version
ID:	251277   Click image for larger version
ID:	251278   Click image for larger version
James
1970 Trans Am
  #154
Old 07-25-2011, 01:34 AM
R 70 Judge's Avatar
more
ID:	251280   Click image for larger version
ID:	251281   Click image for larger version
ID:	251282   Click image for larger version
ID:	251283   Click image for larger version
James
1970 Trans Am
  #155
Old 07-25-2011, 10:50 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Looks great!! Will it be at Pontiac Heaven next spring??
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #156
Old 07-25-2011, 11:36 AM
R 70 Judge's Avatar
Jim
Yeah I hope to make it next year. It should be ready to make some passes near the end of this year. I don't have a trailer yet so I'll have to figure that part out
James
1970 Trans Am
  #157
Old 07-25-2011, 10:24 PM
R 70 Judge's Avatar
More progress today
ID:	251359   Click image for larger version
ID:	251360   Click image for larger version
James
1970 Trans Am
  #158
Old 07-25-2011, 10:41 PM
ronk455's Avatar
Thumbs up Progress
I have been making some progress lately. Finally got headliner installed. Then came windshield and back glass. Interior trim is going back on. Speakers and stereo hooked up. Next is package tray. Still waiting for door panels and seat upholstery. These have been ordered since June 10th. Deadline is fast approaching. May have to throw some covers on the old seat to make norwalk.
ID:	251362   Click image for larger version
ID:	251363   Click image for larger version
ID:	251364   Click image for larger version
ID:	251365   Click image for larger version
  #159
Old 07-25-2011, 11:07 PM
James, Is there going to be hedder clearance issues with the steering shaft??
Ron, looking good!! I see your back window chrome has all the white paint missing like mine!
Keith Collier
Tech advisor
POCI.org
  #160
Old 07-25-2011, 11:40 PM
R 70 Judge's Avatar
It looks tighter than it actually is. My 2" hookers fit no problem. He said that a 2 1/4" primary will also fit without hitting (he had already checked it without me even asking) The steering shaft snakes between the front 2 tubes and the engine is set back like 3-4 inches.
James
1970 Trans Am
