#41
Old 09-09-2011, 10:12 AM
Keith Seymore's Avatar
Originally Posted by Jason67 View Post
After looking at the sheets posted again, looks like most of the ones with TAC have the gas tank straps imprinted in them.
I had always assumed they were from above the gas tank.
K
'63 LeMans Convertible
'63 Grand Prix
  #42
Old 09-09-2011, 11:53 AM
Jason67's Avatar
Jason67 Jason67 is offline
Where would it be on a 72 Pontiac built car?
Mine has A/C I can check it for you.
I found a Lakewood built 72 LeMans sheet inside the driver's door panel, door handle punched right thru it. Not sure on Pontiac built 72.
Jason
  #43
Old 09-09-2011, 01:08 PM
Bermudagto's Avatar
Bermudagto Bermudagto is offline
Ive looked under rear seats and atop fuel tank and no build sheet. My '72 Goat has been sitting tucked away for 25 years so I dont expect the previous owner cared about snagging the build sheet way back then. I'm wondering... are there any other hiding spots that have been confirmed on '72 GTO models? Ill look next behind the door panels I guess. Thanks
  #44
Old 09-09-2011, 03:25 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
It's quite possible that you'll find a build sheet stuck in/to the tar-like underlayment under the carpet, near the driveshaft tunnel.
Regards,
"455HO" Lloyd
  #45
Old 09-09-2011, 03:59 PM
tripower's Avatar
tripower tripower is offline
Thanks! Makes me want to pull off the door panel this weekend on my 71 Lakewood GTO. I'm pretty sure it has never been off the car yet.
Norm J
  #46
Old 09-09-2011, 06:41 PM
It would be interesting if others knew where their sheets were located on the car with TAC on them. Most of those posted look like they were in the interior, where mine was on the gas tank (early 70 build Judge).
Hey Jason, could you post a cleaned up copy of your buildsheet for us to observe ?
Cover over the VIN if you need to, or want to.
I've been collecting and comparing 70 and 71 Judge build sheets lately and making some nice finds on little known / hidden aspects of them. Some guys already know everything, that a lot of us would like to know. So its beneficial and rewarding.
71 Judge thread is already going.
70 Judge thread is about to start.
Would appreciate all examples that can be obtained.
Thanks Man
  #47
Old 09-09-2011, 08:00 PM
Jason67's Avatar
Sure Baron, no problem. First pic is of the one from the top of the tank, second is under the carpet, and third is one I typed up using the two of them to get the complete numbers. When you get the 70 Judge thread going, put these in it if you want. Stripes show A, then an AA beside it. The stripes on my car have never been removed or altered, they are yellow/black/red. Hope this helps.
Jason
  #48
Old 09-09-2011, 08:22 PM
Jason67's Avatar
That would be an excellent find if it was there!
Jason
