I want to purchase some heads to fit a 400 block? not sure what #'s i should be looking for? I was told to find something in the 1960's with 70cc... any ideas would help.
If you are looking for correct code heads for a '69 400 engine, I'm fairly certain you are looking for #16 heads which would be 72 cc's. I'm not sure which casting dates would be correct however.
I do have a set of #16 heads for sale with a casting date of C218 which would make them correct for a late 1968 car. Always an option if you are interested. |
There are a lot of options in the 70cc range.
Big valve with screw-in studs are most popular. 670 / 16 / 62 / 48 / 12 / 13 You'll be around 10.5 - 11.0 CR depending on bore size - milled depth - piston to deck clearance etc... Are you wanting correct 1969 heads ? Here is a website with good head info : http://www.wallaceracing.com |
Thanks, checking out website now. I saw someone on here with #92 heads for sale. Looks like there 70cc also...
not really, just want more compression/power... i have #46 right now in a 350 and have no power what so ever...
If you can find a good set of 670s grab them. They are great stock heads.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
If your #46's on the 350 - are 1973 or 1974 models - those are really some pretty decent heads and have screw-in studs. In previous flowbench tests - they performed as well as many of the 1960's performance heads.
I forget what the chamber cc is on them. They also have hardened seats for unleaded fuel - 1972 and older mostly will not. But have read claims of some 71-72 heads having hardened seats. idunno 1973 and newer will have them though. If you run under 8.5 : 1 CompRatio with hardened seats - you can use 87 octane unleaded. Believe 9.5 : 1 CR with hardened seats - is about max for 92-93 octane unleaded. If you get into higher CompRatio's than that - you'll need race gas/aviation gas blend(s) and lead additives and things like that. It gets expensive in a street car. The best, highest quanity, and cheapest HorsePower comes from Cubic Inches and Camshaft selection. Higher Compression Ratio is not a big factor in street engines until way way further down the line when you're trying to milk every ounce. Another head to consider on a 400cid is the #64 from 1970 455 HO. 80'something cc's IIRC. The higher the CompRatio - the more you have to spend on fuel. Heads without hardened exhaust seats - an added expense to have them installed - or added expense at every refuel for lead additive. Things to consider. |
Maybe they are 1969 #62 heads ? Those are usually around 75cc |
Probably 092 heads. 1966 389-421 4bbl. head.
Gives me a lot to think about
I have sets of #16,#62,#13 #061
69 455/4-sp windward blue under major restoration 69 400/400 waiting for resto |
how much for the 62?
Thad |
