Old 11-21-2011, 08:02 PM
gto mike gto mike is offline
Default Running starter wires
Have a new wire harness for the 67 gto,Ram exhaust,4-speedtalk about a tight fit with a stock starter!Anyway does anyone have a print on the routing for the starter wires.Have the main lead going threw the tube by the exhaust manifold but the other wires are very close to the exhaust.Its a new Ames wire harness.Any pictures or thoughts?Thanks
Old 11-21-2011, 08:14 PM
66Post's Avatar
66Post 66Post is offline
It is a tight fit. I have a 66 and had to extend the existing harness to run it and a 67 battery cable thru the engine mount mounted tube. Maybe someone can post up the approporiate page from the 1967 GTO Assembly Manual. I ended up going to a Summit Mini Stater, solved the hot start and wire clearance issues.
Old 11-21-2011, 08:17 PM
Old Goat 67's Avatar
View E. Need the motor mount horizontal tube.
Name:	Pg 292_12-12.3.jpg
Old 11-21-2011, 11:14 PM
Default 67 gto starter wires
Thanks for the reply.I don't think I have enough wire to run threw the tube.Its a stock harness but they run very close to the exhaust manifold.I do have the battery cable running in the tube now
Old 11-22-2011, 04:23 AM
If you are running Ram Air exhaust manifolds and the routing the wires between the head and manifold as the non Ram Air logs, you will probably cause an engine fire and lose the whole car. The wires will get too hot. I would get a Ram Air engine harness or extend the wires yourself and use the horizontal Ram Air tube to be safe.
Old 11-22-2011, 08:12 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default Wire routing
Old Goat, where did that article come from you posted a picture of the routing of wires? I would like a copy as I can not read it to well from the picture. Thanks
Old 11-22-2011, 08:26 AM
It is a scan of the page from the assembly manual.
Send me an email.
Charles
Old 11-22-2011, 01:14 PM
Default Ram -Pontiac starter
Would any mini pontiac starter work?Or is there one you would rather buy?
Old 11-22-2011, 09:00 PM
cnc's Avatar
cnc cnc is offline
RobbMc Starter all the way
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 11-22-2011, 10:14 PM
66Post's Avatar
Thumbs up
RobbMc has a big following here, I went the Summit route because they where around the corner from me when I lived in Ohio, I bought it and installed it within a few hours. Personal choice as far as I'm concerned.
Old 12-02-2011, 04:17 AM
scott0 scott0 is offline
I installed a summit mini starter on my gto but have not fired the motor yet, how do you like that thing? holding up fine??
thanks for all the good info so far in this thread guys.
Old 12-02-2011, 08:07 AM
66Post's Avatar
Thumbs up
I have been running the Summit mini starter for just over 2 years. No issues at all. Starts in hot summer weather here in SC.
Old 12-02-2011, 01:21 PM
thanks for the info
