| The Body Shop TECH General questions that don't fit in any other forum |
in the summer I took a wire wheel to the subframe, firewall and rad support to clean off the surface rust. Well it is back because I didn't seal it in time.
So I am wondering what product you would recommend I spray over it after I clear off the recent surface rust to prevent this from happening again? And on top of that I want to paint the rad support, sub-frame, and firewall all a semi-gloss black. I don't have a sprayer or anything so it would have to be of the brush variety or rattle can. Looking for suggestions in best way to de-resust and paint or product suggestions for the job. Thanks! |
Since I found out about this stuff, I use it all the time.
http://forums.performanceyears.com/f...ighlight=gibbs http://www.gibbsbrand.net/home.html http://www.gibbsbrandlubricant.com/ |
http://forums.maxperformanceinc.com/...d.php?t=686601
very similar issue here. I would neutralize the rust with the phosphoric acid, clean it off with surface prep and spray with a rattle can of rustoleum. Its the same product inside the cans that is in the quarts of rustoleum! Lots of guys shoot the rad. support and frame with rustoleum, its a good paint. I would prime it first, with primer in a rattle can. You will get better results with a rattle can than a paint brush. |
thanks guys, someone had also recommended I use brake caliper paint but I haven't looked into that yet.
