#201
Old 05-25-2012, 11:58 PM
LeighP's Avatar
LeighP LeighP is offline
Nice job...very clean underneath!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #202
Old 05-26-2012, 10:25 AM
Originally Posted by njsteve View Post
So, 7 years and 3 days after this:
That creeper looks like it's seen a bit of use in the last 7 years...
Nice work - car looks mostly very clean.
  #203
Old 05-26-2012, 10:42 AM
Norwood's Avatar
Norwood Norwood is offline
That car is SICK........If I drive over how much to do the bottom of my undercoated back in 76 car. I really would like to see what mine looks like under that coating, but I'm just to damn old to tackle that one.
  #204
Old 05-26-2012, 09:43 PM
njsteve's Avatar
njsteve njsteve is offline
Today I tackled the trunk area. This car was Ziebart rustproofed back when it was new and that stuff is nearly impossible to remove. Solvents just smear it. It's almost like roofing tar and it's about 1/8" thick. A different, and thicker, but equally adhesive version was over-applied later, on the GM replacement quarters and tail panel that were replaced in the 1980s. The hot water seemed to work but VERY slowly. Like around 5 seconds of close up blasting to remove one square inch. It was mind-numbing and carpel tunnel initiating to say the least.
Here's the before shots:
  #205
Old 05-26-2012, 09:45 PM
njsteve's Avatar
And after about 6 hours of blasting.
I tried to save as much of the original splatter paint but in some spots it came off very eaily while in other areas, it was hard as rock. The Ziebart stuff worked as the only rust I found in the trunk floor were the four tiny pinholes in the lower right of this photo to the left of the drain plug. The rest of the dark areas are due to the surface not being completely dried off yet.
  #206
Old 05-26-2012, 09:48 PM
njsteve's Avatar
I'll trade you for the front and rear springs off your 70...and a lot of arthritis medication!
  #207
Old 05-26-2012, 09:50 PM
njsteve's Avatar
When I was done with the trunk I spent an hour or so with a rag soaked in a little diesel fuel to clean off the reside on the underside of the floor pans. Here's what they looked like with a little elbow grease appled:
  #208
Old 05-26-2012, 10:05 PM
njsteve's Avatar
In looking at the frame rail damage/rust it doesn't appear to be as bad as I initially thought. (I hope).
The undersides of the lowest portion of the rear rails by the front leaf spring pocket both have the outer layer corroded on the bottom and sides. It is also evident on both inner and outer sides of that area, next to the E-brake cable. There are three separate panels that sandwich together at that point and it looks like just the outer one held the crud and rusted, as this is the lowest point on the rail (lower than the drainage hole unfortunately). It also didn't help matters that the delivery truck driver used that spot as the hold down for his cargo chains.
Pass side:
Driver's side:
  #209
Old 05-26-2012, 10:06 PM
njsteve's Avatar
The other rail problem was in the rear where the aftermarket exhaust had all it's weight on the tailpipe hangers after the crummy, universal hangers that were sheetmetal screwed into the rear bulkhead, ripped out. It appears that the reinforcement section of both rails were not properly tack welded in originally, as the pass side area pulled away and cracked the frame under the panel.
Pass side:
Driver's side:
  #210
Old 05-26-2012, 10:10 PM
njsteve's Avatar
And the solution:
I bought a pair of the new reproduction frame rails to use for donor sections.
I also bought a set of the repro sway bar mounting brackets as the ones on the car have been welded so many times, they actually welded a bolt across one of them to keep it together.
  #211
Old 05-26-2012, 10:53 PM
Formulabruce's Avatar
Grats Glad you found those brackets. I couldnt find the guy through ebay.
There are numbers stamped in them you may want to fill with some solder,brass..
The 3 piece front area of the rear frame is also attached to the rocker and actually completes the frame. rear to rocker, to subframe in front. Make sure that its not rusted and or welded to the rocker there correctly . That is the frame strength of the car.
Looking great. Keep up the good work!
PS. The trunk, the dark areas not dry yet are a bit pitted, I would consider coating it with some POR15 after etching it. any other paint would just trap it and make it rust through the spatter paint. Just my 2 cents...
  #212
Old 05-27-2012, 03:27 AM
LeighP's Avatar
See, thats what happens when you tie a car down to the body...the body bounces on the springs, the tie downs load and unload and cause damage where they're attached.
You'd think a professional would know better. You always tie down the unsprung part of the car...the rear axle, front suspension etc...that way the car is secured, but the springs can do their job and take the loads while the body moves around.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #213
Old 05-27-2012, 06:36 AM
njsteve's Avatar
The rockers are really nice and solid, othe than theass side that has the hole in the lower outer wheel house. (which actually made prseeure washing insid that rocker, really easy).
Yup, I was planning that same route with the POR15 on the pits.
Here's that link to the brackets: http://www.ebay.com/itm/70-73-Camaro...9#ht_500wt_922
  #214
Old 05-27-2012, 11:24 AM
These cars were delivered from the factory with a T or hammer head hook slid in that slot and twisted, or locked into place, and then "tied down", removing much of the spring. This was factory approved method and I have been there for delivery of several ordered vehicles and helped take them off a carrier myself. On older cars, hooking to an axle ( without a strap, IE a "j" hook" ) could damage brake lines, slide around some and rip out spring mounts. When a cars springs are working when on a trailer, the car is "Tied on". This method is tied "down"
The Carrier who moved Steves car only did what was originally done. The cars metal wasnt up to it, this has happened to me too. On cars in a carrier, or enclosed for long distance, you do not want the car moving, or the cars springs much. In the rear of the car, this is the strongest part of the frame.
  #215
Old 05-27-2012, 05:20 PM
njsteve's Avatar
Interesting contraption there.
It also didn't help that it had to travel around 3500 miles to get here. That's a lot of stress on a 40 year old (car, that is). :-)
Today's project was getting the heater core out. It actually went rather well. You have to remove the pass side inner fender to do it properly in order to access the lower studs and the heater hoses. Otherwise you will spend hours with extensions, lost sockets and scraped hands. It took me ten minutes to pull the inner fender and then another ten minutes to get the nuts off the studs. Once inside the car you have to pull the glove box door, glove box and the A/C ducts from one side to the other. That way the heater assembly comes out easier. In total it took about an hour to get everything out of the car. Now I have to wait for the new core to arrive....
While the heater was out I was able to see the VIN stamped in the firewall which was a reassuring thing. I then wiped the giant black seam sealer waterfall away from the area and was able to do a pencil tracing of it. Remember it is upside down and backwards since it was stamped from the engine side - so don't have a heart attack if you try this on your car and it at first doesn't match. Take your tracing and hold it up to mirror and it will magically transpose. Or you can always just flip the photo in your photo editor program.
  #216
Old 05-27-2012, 05:26 PM
njsteve's Avatar
After the heater core removal was accomplished I crawled back under the car and started scrubbing some more with the diesel fuel and a rag. That took the rest of the day.
Here's a shot of one of the sway bar mounting brackets. Looks like a junior high school shop project on "Learn How To Weld Day." They acually tried so many times that they burned through the rail under the bracket.
  #217
Old 05-27-2012, 05:34 PM
njsteve's Avatar
And here is the final result. After these photos were taken I snaked the old exhaust back over the axles and reattached it so at least I can drive the thing again. I will probably be getting the Gardner Exhaust for this car like I did with the 72 T/A. I'll have to wait til after the frame repairs get done, though. Though they go together very easily, that is one system that you want to install once and not take apart again. (looks too pretty to risk scratching it up).
You can see the original black overspray nicely, in these shots...and the spots I missed under the fuel/brake lines. I'll wait til its time for the frame repairs to remove those lines and clean underneath.
  #218
Old 05-27-2012, 05:35 PM
wow you are movin right along!
That bracket looks like a stick weld ( ugh)
Did you test the AC in your car Steve>?
  #219
Old 05-27-2012, 05:42 PM
njsteve's Avatar
And the final item of the day was adjusting the clutch, which was grabbing way too high. On a hunch, I pulled the actuating rod and noticed the same wear that was on my other car. This groove was cut halfway through, eventually it would have snapped off. I will be replacing both rods: the bellcrank to fork rod, as well as the pedal to bellcrank rod as they both tend to exhibit the same wear patterns.
  #220
Old 05-27-2012, 06:02 PM
njsteve's Avatar
I'm still collecting parts...and need freon, in case anyone has a few spare cans left they aren't using. The car has a new condensor but sadly it was the wrong one and has the outlets in the completely wrong locations.
Things I still need:
1) correct expansion valve with short capillary tube (the replacement all have this way-too-long tube that really looks bad.)
2) correct condensor
3) metal tab that goes on the bracket that holds the "trumpet-looking hose" to the front of the compressor
4) metal hold down tab that retains the metal hose coming from the POA valve.
