| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Dodge uses a half moon disc for it's cam sensors on the 318, and the principle would be the same only a shorter singal interval. I don't know how other ECU's would handle it, but the MegaSquirt would probably work perfectly off a setup like that as long as the timing chain or something doesn't screw with the signal. Just needs one pulse per 720* of crank rotation. Definately has given me something to think about for possibly another engine, or even the OHC six.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
But, I want a sharper rising and falling edge. A very simple flat tab with a 90 bent into the end will work. Possibly cut off material on either end of the polled area to create loss of signal. BTW, the Chevy Vortec dizzy uses a poll gear arrangement as well. It's another one to look at. I actually have a modified front cover that also works, but it's not as simple as the fuel pump block off. It requires precise positioning and the possibility of cam trust can affect the min/ max free air tolerance. The easiest answer is the oil pump drive/ sensor. All in one, wiring to the rear of the block. This is why I considered the Ford Explorer sensor. Again, easily accessible to replacement parts and cheap to boot. The hard part is grafting the pieces together and I have attempted to source some dizzys for this purpose. I will be machining the parts at work, but I am trying to come up with a dirt cheap, DIY for the masses method of doing this. But at hand, Where's our EFI specific forum? ![]() Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
EFI controller like MS can make for a fine ignition controller and for data logging if you really dont want efi or feel you have to run a carb... I think a seperate efi forum would be nice. |
