| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
I too would love to see a specific efi forum.
I just got my 2011 camaro pump, so will be cutting up a brand new stainless tank to get out mounted. I am also building a oil pump drive/ cam position sensor. I did consider and still may use, the now empty hole where the mechanical fuel pump used to be. I have the drawings, and it would be very easy to machine a poll gear in place of the fuel pump eccentric. Then a very simple block off plate housing a hall sensor. The only issue I have with it is, I want to use standard off the shelf parts in case of a roadside failure. For this reason, I am still working on my oil pump drive setup first. Maybe, I'll get more ambitious down the road. Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
