#121
Old 03-21-2012, 11:05 AM
webfoot's Avatar
webfoot webfoot is offline
I should've put those away and put some junkers under it, but the ones it had were old bias ply tires and were all shot so this was easier, should have probably jacked it up off the ground over the winter.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #122
Old 04-03-2012, 11:15 PM
webfoot's Avatar
No photos but I have been spending a lot of time in the garage sanding skim coats. One more quarter panel to go but the doors and fenders are on the car. lucked out on the pass side door, the rear gaps were perfect my first try. Bet I could never do that again. Wife is due to have our first (ever) baby in October so I am going to go gangbusters on this thing prior to that. Today I told her "I bet I can have that thing painted in 2 months!".
-Jeremy
  #123
Old 04-03-2012, 11:42 PM
Pontiac_Defender's Avatar
Pontiac_Defender Pontiac_Defender is offline
Congrats on the baby!
  #124
Old 04-16-2012, 10:26 PM
webfoot's Avatar
Started blocking high build. I should have laid down more coats the 1st time and I used a different gun than usual so it wasn't set up quite right. Now that most of this is scratched off when it warms up a bit I'll lay down another 3 coats. (only did 2 last time)
-Jeremy
  #125
Old 05-02-2012, 12:31 PM
webfoot's Avatar
Blocking is almost done! Realized on the pics above why they are so leopard-ish, i didn't put nearly enough coats of high build on. But its fun to sand for practice., I guess. This is after 4 or 5 coats and blocking with 220.
I have since sprayed 2 more coats and blocked again with 320 and it is as smooth as glass, and all my lows are gone. Going to go over again with 400 and still undecided if I will wetsand with 600 or just stop at 400.
-Jeremy
  #126
Old 05-02-2012, 03:54 PM
Hmmmm.....I just saw a set of pictures that look very much like those pics on the Chevelle site...lol
Old 05-02-2012, 04:22 PM
webfoot's Avatar
Yep, I own one of those "C-word" cars too!
Been a member there over 10 years.
-Jeremy
  #128
Old 09-22-2012, 12:43 AM
webfoot's Avatar
Not much happened this summer, wife was on hospital bedrest 2 months in portland (2.5 hrs west of here), son in NICU for 3 weeks and as of monday we are finally home. Needless to say I have missed my garage something fierce and hopefully get a bunch done tomorrow.
20 year reunion is next year, now wouldn't that be a great goal to set for getting this thing done?
-Jeremy
  #129
Old 09-22-2012, 07:55 AM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Jeremy, it will come together. I took a year off my project during the body work phase, just because.......
Congrat's on the new family member.
Rick
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
  #130
Old 09-22-2012, 07:46 PM
keith h's Avatar
keith h keith h is offline
1st Congratulations with you baby boy I hope all is well!
Nice work on the GTO!
It's ok you're amongst "C-word" friends
370 Posts and holding...
  #131
Old 10-27-2012, 03:16 PM
webfoot's Avatar
Thanks Rick and Keith! He is now 2 months old and doing great & growing like a weed.
I ended up cutting the patches out of the pass side because I was never happy with the fit. Got a quarter skin and after beating the UPS dents back out of it, (it was obviously dropped from a fair height right onto the back end of it) I am 100 times happier with the way it fits. Hood and trunklid are ready for primer, pass quarter is ready for skimcoat and a ton of sanding.
Next I gotta work on the endura some more and figure out how to go about getting the jambs done.
I was planning on scuffing the jambs and shooting with epoxy and then high build, and sanding with 220 then ??? recommendations on doing this welcome!
-Jeremy
  #132
Old 10-30-2012, 03:43 PM
More congrats on the young'n.
Jeremy, I just scuffed my jambs, washed and degreased thouroughly and sprayed. Unless you've got scratches and gouges in the original paint that you're concerned about, you won't need the high build. You won't need the epoxy either if the original paint is still there and not rusty..in my opinion, that is...
Old 11-02-2012, 05:53 PM
webfoot's Avatar
Thanks Greg. Yeah I didn't think there was too much to doing jambs, just wanted to make sure.
Hood is nearly finished! Also, got this unit in the mail today, looks great!
-Jeremy
  #134
Old 04-18-2013, 08:35 PM
webfoot's Avatar
I have been working a lot but not taking many photos, well because there really isn't much need for many at this stage.
Got the headlight doors done, well the hard ones anyway. Not perfect but I'm pretty happy with how they turned out.
Starting to work on jambs now, lower valence is the last metal piece and then endura. Hoping to have some color on the jambs soon. That trunklid gave me a hell of a time. I warped it pretty good sandblasting and had to use the ol shrinking disk pretty intensively so an otherwise harmless panel took a good number of hours. I had to patch the lower corners and one on the inside.
Not sure why I felt so compelled to buy this NOS ash tray, but I guess I liked that it wasn't all rusted to hell and has the shiny zinc coating on it.
-Jeremy
  #135
Old 04-24-2013, 07:36 PM
webfoot's Avatar
Finally did some jambs, really impressed with this color! Paint is TCP global's house brand. I haven't shot BC before but I have never had paint lay down this well before. I was also using my devilbiss finishline 3 for the first time. No orangepeel at all. Main screwups was where I let the air hose hit the trunk opening and where I kicked the lower door jamb when I was trying to step into the car to paint the top of the window frame. I did NOT spend a lot of time on prep since it was "just a jamb" and final sanding was with 400.
Pretty much just have the endura left to do now.
-Jeremy
  #136
Old 04-25-2013, 08:28 PM
Does TCP global offer factory colors or did you just pick a color that you like? If I recall, yours is Meridian like mine isn't it?
After I get past the major obstacle of rigging up some type of paint booth outside...grrr... I need to order some paint.
Old 05-20-2013, 12:39 PM
webfoot's Avatar
They have factory colors. On their website is a listing of factory color chips by year and manufacturer, so you can go to 68 pontiac and see all their colors and then fill in exactly what you want by color code. Mine is also meridian, correct.
Endura is finished! This was not as hard as I thought, and that SPI epoxy primer sands really well.
Next is one small spot on the LH fender to fix then block it out, and finish prepping the jamb areas, then wetsand the whole thing with 600 and it'll be ready for paint.
I have nicknamed my chevelle "james bondodust" during this project, for obvious reasons.
-Jeremy
  #138
Old 06-03-2013, 06:22 PM
webfoot's Avatar
That "small spot" on the fender turned out to be a pretty good sized pain.
Got some more jambs done today. All that is left is the RH fender and door. Still crazy about that color.
I got a little better at shooting the SPI universal clear. This stuff needs to be laid down THICK. I had one place where I sprayed it on (or so i thought) way too heavy and it wrinkled some. It flattened itself out completely and looked fine. (fine for the underside of the trunk lid, anyway.
-Jeremy
  #139
Old 06-03-2013, 09:21 PM
Looking really good Jeremy.
Old 06-05-2013, 03:28 PM
Judas Judas is offline
Looking great! Not much more to the goal line to go!
-J
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
