I apologize for being a bit thick headed here but I still don't get this part...... Are you actually plumbing the heater feed into the "intake" as in intake manifold water crossover? Or do you mean the flow goes into the "intake" on the timing cover/pump housing? May be that a picture would help me here... I have a '72 model so it may be the difference in the design of the timing cover/pump housing for the '68 is hurting my small brain I don't know for sure that routing this one way or the other is affecting the temps but every little hindrance to proper cooling system function will add up..... Anyway, if you could post a picture of this I would appreciate it. I'm constantly trying to learn here. Karl
Hopefully I will have gained a lot of knowledge from this adventure by the time its fixed.
I called autozone, napa, o'reilly's, advance, and pepboys and not only do none of them have them but they cant get them. I looked on ebay and didn't find them but did find a complete engine set with the head gaskets! The hunt was over and I could focus on other things. I check my ebay inbox and had a message regarding my order. They were informing me that there was a mistake with their listing and that the Victor's were not available but, the felpro's were... Back to my dilemma. Should I order custom copper gaskets for $100 each or SCE's 4.125" bore sized ones compared to the felpro 4.3". The pontiac 350 has a bore of 3.8". What do y'all think?
1967 GTO (project, surprise gift for dad) -Lexus pearl white paint -2005 gto brakes, irs independent rear suspension axle, -and wheels. -2006 gto front and rear seats 1972 Vega -waiting for turbo v8 1976 Nova -owned since high school, it's been sleeping for over 15 years! |
I would call Butler performance and ask them the best option.
Jray, I actually did call Butler first and they said they don't stock any for the 326/350's.
Dave, The guy "Scott" aka Nanettestore on ebay is the guy I ordered the complete set from and he's on the hunt to see what he can find. He said his warehouse would normally let him know when something is out of stock or discontinued but, they failed to do so for these engines. I explained to him about the felpro 8518pt's being way too big and causing problems. I can't believe they haven't had there door knocked down because of this. Specifying the wrong head gaskets cause a lot of costs in labor. Not to mention if it causes engine damage.
I don't mean to change the direction of your post Jray but, I don't have much hair left neither. Well, on my head that is..
Look at the sponsors for this site. Many of the engine builders can get them. They might run some coin, but worth it. I don't under stand why they stopped making gaskets for 326/350. They are GREAT engines and make decent power for cheap. I have a 326 in a 4200lb wagon and you would swear it is a 400. Here is one,. http://www.ebay.com/itm/One-1968-197...d33d73&vxp=mtr This one shows the correct gasket... http://www.ebay.com/itm/Victor-FS340...sories&vxp=mtr
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Karl
Have not. Will do.. Looks like Cometic makes some good ones and they're very specific with bore diameter and thickness but, pricey and could take a couple weeks to receive.
Well 195-205 is the best I have been able to achieve. Running down the road or sitting idling it stays at that temp. Even after going to the 6.5 waterpump pulley that's the best I can get. I shot several areas of the motor and radiator with the infrared and I have a wide variety of temps. Temp sender housing is 199 and the radiator is 148-168 , the heads are 178-215 and the heat crossover in the intake is 270. Any thoughts on these numbers?
195-205 seems okay. Not sure about the 270 in the intake but, others may know better.
Karl
