#181
Old 08-20-2012, 08:39 PM
jimmo's Avatar
jimmo jimmo is offline
Originally Posted by 1967Tempest View Post
I have been subscribed for awhile. Following the action so to speak. I would agree that I would do both, DIY and by the complete kit.
I looked in the thread was there any increase in cooling capacity?
Have you brought this to a cruise/show?
No increase, as a matter of fact according to my stock v pulley sizes the serpentine system spins the water pump .06 rpms slower to a 1.17 to 1 ratio. The system in my car has the larger diameter water pump pulley which slows it down even more, .12 rpms for a 1.11 to 1 ratio from the stock 1.23 to 1 ratio. My car has a 5 blade clutch fan and runs very cool.
If a motor is running hot I dont think its related to a slow spinning pump as the thermostat restricts flow as needed. In my experience undersized or old clogged radiators were the culprit most of the time.
I havent taken it to any shows yet. been meanin to stop at the local friday nights just havent made it yet.
If anyone lives in the ne pa or jersey area I'd be glad to show it to ya.
  #182
Old 08-20-2012, 08:50 PM
Ollie's Avatar
Ollie Ollie is offline
Originally Posted by jimmo View Post
I thought you were working on spacing your Sanden?
Yes I have preliminary drawings to move the compressor forward to position the belt the 5 5/8 " forward of the engine. I am in the process of reacquiring all the necessary parts.
I purchased the Camaro belt tensioner Gates 38145 all the spacer you listed in post 153.
I now need to Purchase a T6 pulley for the Sanden Compressor.
The Dayco 89001 you are using in place of the Subru pulley?
Its ok to giggle and snicker, Dont laugh and point
  #183
Old 08-20-2012, 09:28 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Let me know if you are going and I can meet ya. Chatterbox any Saturday in your Future??
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
  #184
Old 08-20-2012, 09:31 PM
jimmo's Avatar
The Dayco 89001 you are using in place of the Subru pulley?[/QUOTE]
Yea, almost any idler in the 3" diameter range can be used. I chose that one because its extremely popular.
  #185
Old 08-21-2012, 03:01 PM
JC455 JC455 is offline
Jimmo,
Do you need to space the lower pulley forward with the factory A/C pulley ring- or any other method?
John
IG: @crawdaddycustoms
  #186
Old 08-21-2012, 04:43 PM
Ollie's Avatar
Originally Posted by JC455 View Post
Jimmo,
Yes, use the spacer to maintain the pulley alignment
  #187
Old 08-21-2012, 08:46 PM
jimmo's Avatar
Thats correct but I want to add something. I read somewhere on one of the threads here, might have been the March set up, that pontaic used an offset balancer on non AC cars. If your car is equipped with ac you will need the ac pulley or equivalent spacer however I think if its a non ac car you shouldnt need a spacer as the balancer is a tad forward.
Someone please chime in and correct me if I am wrong. I just dont know for shore but I remember reading that somewhere.
  #188
Old 08-22-2012, 10:11 AM
Ollie's Avatar
No, there is not a parts listing for two balancers one for AC cars and one for non AC cars.
The cost effective solution would be to use the ring spacer on the non AC cars.
How ever I don't think it will make a difference as the mountings are being moved forward with custom spacers to line up with the Ford crank pulley.
Use or non-use of the spacer ring could be determined by the total length of spaces required to align the belt.
  #189
Old 08-22-2012, 10:08 PM
jimmo's Avatar
hahaha, my bad. I never gave it a thought to look up part #s. Thanks Ollie
  #190
Old 09-13-2012, 08:33 AM
Ollie's Avatar
Default DAYCO PULLEY
Looked up the Dayco pn 89007 on Amazon.com the listing only showed the pulley.
Is the bolt, washer, nut and spacer included with the pulley?
As shown in the E-bay listing.
Name:	DAYCO PN 89007.jpg
  #191
Old 09-13-2012, 09:12 PM
jimmo's Avatar
No, I machined the spacer and gathered the rest of the hardware to go with it. The dayco part# is the pulley only.
  #192
Old 09-15-2012, 09:04 AM
Ollie's Avatar
OK, Jimmo keep up the good work. will be standing by waiting for the availability of the idler pulley extension. So I ca start to work on that side of the serpintine system.
Got a notice from the PO that they are holding a package too large for the mail box.
Should be the Sanden compressor with a serpintine pulley I bought on E-bay.
  #193
Old 09-16-2012, 08:45 PM
jimmo's Avatar
Just got the other pieces in from the waterjet. here is a pic of them in raw form. both need a little work to be bolt on ready but at least they are finally here.
The aluminum will receive threads at the top two holes and a counter bore on the other mounting hole to keep the bolt head away from the path of the belt.
The smaller steel bracket will get a threaded spacer welded to it to accept the ac bracket. This will perform the same function as the 1" thick aluminum one I made previously.
  #194
Old 09-17-2012, 12:42 AM
Ollie's Avatar
That's great jimmo. I want a an idler bracket as soon as they are ready.
I was correct the package at the PO is the Sanden AC compressor with the serpentine pulley. will post photos of the mock up as soon as I get it put together.
  #195
Old 09-17-2012, 06:45 AM
jimmo's Avatar
Nice! I cant wait to see how it turns out with the sanden. Ill machine the spacer in the next day or two and p.m. you when its ready.
  #196
Old 10-09-2012, 08:54 AM
Ollie's Avatar
Bringing this back to the top.
jimmo is making great progress refining his DIY Serpentine belt system.
Anyone else have up dates on their DIY Serpentine belt install.
I've purchased jimmo's idler pulley extension bracket shown above in post 193.
I purchased a CS 130 alternator from this E-bay seller billh6800, who will fabricate a custom CS 130 alternator.
Purchased a power steering pump with the serpentine pulley. Both should arrive by the end of the weed.
Also found this site for Goodyear Gatorback Serpentine belts. The 6 rib belt Part number, length from 29" to 120" in 1" increments.
shouldn't have any trouble selecting a belt.
Check it out to determine what belt length and part number to use.
http://www.goodyearep.com/productsdetail.aspx?id=3128
  #197
Old 10-09-2012, 10:02 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Ollie, I am looking forward to seeing your Sanden compressor install, as I would rather go that route instead of using the R4 compressor, if possible. Please post pics and parts lists when you can. What vehicle are you installing in? What will you be using for hoses, evaporator, condensor, etc?
I'm installing in a 65 Grand Prix. I don't mind changing out the condensor for a modern unit, mine developed a leak anyway. But I'm not sure I can adapt modern stuff to work with my 1965 evaporator...if that is even possible.
As for now I'm still running the serpentine belt on the water pump, alternator and power steering only..it's holding up OK. I have noticed that belt tension must be kept pretty tight since this system uses no tensioner.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
  #198
Old 10-09-2012, 10:20 AM
Ollie's Avatar
AROWHEAD
What year heads do you have on the engine. The vintage Air bracket mounts to the two bolt bosses on the side of the head. The Classic Auto Air bracket mounts to the bolt holes on the front of the head.
This set up is on a 79 TA, using the stock GM AC. The only change is converting to a Sanden compressor, using the Vintage Air Snaden bracket
http://www.vintageair.com/DownloadsS...%20PONTIAC.pdf
Check out E-bay seller, Classic auto Air
http://www.classicautoair.com/downlo...ntiac6-403.pdf
They offer any combination of hose and fittings.
  #199
Old 10-09-2012, 10:44 AM
quicksilver97ta's Avatar
AROWHEAD
RE: VA Bracket
Either thats a new one, or an old one, or they have more that one Pontiac application because my VA bracket, installed new 2 yrs ago, mounts to the front only.
  #200
Old 10-09-2012, 10:56 AM
Ollie's Avatar
Originally Posted by quicksilver97ta View Post
RE: VA Bracket
Either that's a new one, or an old one, or they have more that one Pontiac application because my VA bracket, installed new 2 yrs ago, mounts to the front only.
Interesting.
The link is to the latest Vintage Air on line catalog.
Maybe there are two bracket listings. I know the the AC compressor mounting changed in 1969. Prior to 69 the AC bracket bolted to the engine with two special head bolts. in 69 the AC bracket bolted to two bosses cast in the side of the head.
Do you have a PN. or post a photo of the bracket
