Old 10-13-2012, 01:28 AM
62 tempest nashville's Avatar
62 tempest nashville 62 tempest nashville is offline
Default 428 SD
How desirable is a 67 428 SD ??
Compete stock engine, stock heads and even factory exhaust manifolds.
minus intake and carbs,,,, i know it was a 3 x 2
What made the 428 a super duty that year ?
Can it be the monster the 421 SD was ?
Old 10-13-2012, 05:57 AM
BOB VIDAN BOB VIDAN is online now
No 428 SDs. Check all the numbers and date codes on theblock, that should tell what's there.
Old 10-13-2012, 07:31 AM
stevep's Avatar
stevep stevep is offline
Do you mean 428 HO?
Old 10-13-2012, 09:58 AM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Get the numbers and some pictures.
Two freeze plugs or three?
Old 10-13-2012, 10:16 AM
Keith Seymore's Avatar
Also - no tripowers in '67. Last year for the tripower (except Corvette) was '66.
K
'63 LeMans Convertible
'63 Grand Prix
Old 10-13-2012, 10:29 AM
Steve Barcak's Avatar
all the replies above are correct.
No such things as a 428 sd.
No multiple carbs in 1967
Someone is feeding you misinformation.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 10-13-2012, 02:23 PM
guys says thats what he has ???
I never heard of it either..
i will get some numbers to see what this man is talking about.
he sure acted like he knew what he was saying ?
Old 10-14-2012, 12:46 AM
Engine-Ear's Avatar
I think "the man" was listening to either Tokyo Rose or Miss Information.
Take pictures and post them.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 10-14-2012, 01:07 AM
There is alot of guys who can make up a good story but the past posts are all correct, the guy is feeding you a line hopeing you will take the bait & fish you in for some quick big bucks. Again NO 428 SD's & NO tri-power (3x2) for any Pontiac after 66. It can be put on & it works but None from the factory that way.
Old 10-14-2012, 01:19 PM
Diego Diego is offline
….or, simply, the guy is misinformed - there's plenty of people like that.
Old 10-14-2012, 02:25 PM
He keeps referring to this,
you should hear all the names this guy is calling me.
About the Pontiac 428 Engine
X
Rob Wagner
Rob Wagner is a journalist with over 35 years experience reporting and editing for newspapers and magazines. His experience ranges from legal affairs reporting to covering the Middle East. He served stints as a newspaper and magazine editor in Saudi Arabia and the United Arab Emirates. Wagner attended California State University, Los Angeles, and has a degree in journalism.
By Rob Wagner, eHow Contributor
About the Pontiac 428 Engine The Pontiac 428-cubic-inch V-8 engine was only available from 1967-1969. It powered such cars as the Grand Prix, and was in limited numbers on the GTO and Firebird. Its origins can be traced to Pontiac's development of the V-8 in 1946.
Other People Are Reading
Pontiac 428 Specs
Specifications of a 1968 Pontiac Catalina
Print this article
Background
General Motors' Pontiac was slow in developing the V-8, clinging to the inline-eight engine that served Pontiac since 1933, but relented in 1952 to match other GM engines, according absoluteastronomy.com.
428 Origins
The 428 is derived from the 421-ci V-8 that debuted in 1961 as Pontiac's Super Duty version, and was used in NASCAR stock car racing, according en.allexperts.com.
Sponsored Links
Download Your Manual
Your Manual is Ready For Download Download it Here. 100% Free.
produtools.com
Long Journal
The 421 and the 428 were the first of Pontiac's big "long journal" V-8s, with the 421 featuring large 3.25-inch main journals, a 4 3/32-inch bore and 4-inch stroke, according absoluteastronomy.com.
Bigger is Better
The 421 was produced until 1967, when the 428 debuted with a larger 4 ¼-inch bore and the same size stroke and main journals, according to yearone.com.
Slight Changes
Pontiac stopped using steel crankshaft in 1961 and shifted to cast iron, but used a stronger alloy in the cast iron for the 1969 428s, according absoluteastronomy.com.
Short-Lived
The 428 was only available in large Pontiacs, and a few were factory installed in GTOs and Firebirds before being replaced for 1970 by the 455, according to absoluteastronomy.com.
Read more: About the Pontiac 428 Engine | eHow.com http://www.ehow.com/facts_5497951_po...#ixzz29IcBMxHs
Old 10-14-2012, 02:33 PM
Well, there's no reason for the guy to call you names, but why not show him some documentation via the catalog? Go to tocmp.com for the brochure.
Whatever the case, the thing you posted above has no credibility based on the "428 installed in Firebirds and GTOs" alone.
Old 10-14-2012, 03:00 PM
Short-Lived
I can't imagine that an astronomy site would make any mistakes about Pontiac engine availability....
K
'63 Grand Prix
Old 10-15-2012, 09:16 PM
Stu Norman's Avatar
Stu Norman Stu Norman is offline
Wow, the BS is getting deeper.
Stu Norman
Msgt. (ret)
Hortonville WI
May the torque be with you.
Old 10-15-2012, 11:18 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
"He keeps referring to this,
you should hear all the names this guy is calling me."
To me name-calling= ass whipping
"Bigger is Better
The 421 was produced until 1967, when the 428 debuted with a larger 4 ¼-inch bore and the same size stroke and main journals, according to yearone.com."
A 428 with a 4 1/4" bore, really! Pure stupidity.
[SIGPIC][/SIGPIC
Old 10-16-2012, 01:05 PM
The seller sounds like the clown that tried to convince me he had a "factory installed"
Tri-Power on a '65 LeMans 326.
Dr. Thomas Sowell
Old 10-16-2012, 01:13 PM
BigAquaBonney's Avatar
BigAquaBonney BigAquaBonney is offline
The 428, and 326 , and 400 was derived from the 421, and 389. It doesn't make it a SD.
There were no mulitple carbs.
It's probably an HO that someone threw a different intake on.
Old 10-16-2012, 01:18 PM
63gpman's Avatar
63gpman 63gpman is offline
How much is he asking for it?? May still be worth the money?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 10-16-2012, 09:22 PM
Stu Norman's Avatar
Hey, I'll sell you a 1969 326 SD, X-code block, COPO, NASCAR, factory experimental (and every other buzz word the Chevy guys use) with factory high performance manifolds, and I won't call you names.
Stu Norman
Msgt. (ret)
Hortonville WI
Old 10-16-2012, 09:23 PM
I heard it has tunnel port semi-hemi heads with 4 valves per cylinder.
