#401
sheet
#402
HI TOM. I WANTED TO USE STEEL IF I CAN GET IT. I DON'T WANT TO USE ORIGINAL CARBS FOR THIS PROJECT.....TAKE CARE JERRY
#403
I made my own jerry, I used some cardboard
to make a template then tranfered to a piece of alluminium. Worked great. GT. |
#404
69 Judge RAIII 4SP 2ND OWNER 63 Catalina 421HO 4sp 66 GTO Conv 4sp 73 Trans Am 455 4sp http://www.sdperformance.com/ Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds. |
#405
To be continued...
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. 1966 GTO Hardtop - PS 14.84 @ 97mph |
#406
#407
I had one person from the board here really interested but could not make it work with what he wanted to do. I understood completely.
Had a few tire kickers. Had two guys from Ebay that wanted it to put other motors in (I will leave it at that). One made a really good offer but I said no way! So I am keeping it for now, completing my upgrade, and shooting for POCI/GTOAA in Dayton 2013. After working on it this weekend... I kinda got the bug back. It really is a NICE car. Kip
#408
Looking forward to seeing you and "Born to Late" this coming year at POCI and Tripower Nats! |
#409
#410
One of the best reasons to keep the car!! Looking forward to seeing them make a pass!
#411
I agree as well. My wife and I decided to keep our 61 for now. Too cool of cars to part with.
#412
'After working on it this weekend... I kinda got the bug back. It really is a NICE car.'
Make it a really NICE, FUN, and EXCITING car....put a Jerico in it. Nothing beats a 4spd Nostalgia race car!
#413
Lots of time has passed since the Lemans has been back.
This is the build that never ends. After all the stumbles with engine issues it seems to be heading in the right direction. A recent Trans upgrade has put 63 close to where he should have been several years ago. It’s been staying somewhat consistent with mid/high 10:40's and should be able to get it down a bit more with some tuning. But of course as in the past the season is over and next year it will be like starting over. Hang in there 63 it’s only Money ![]()
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
#414
Jeff,,,,Thats one fine looking car!!!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
#415
Finally had some time out in the garage today to work on the car. Satchell link rear suspension is coming along, and I almost have all of the lower trailing arm mounting bracketry fabricated and tacked into place. Once it is all tacked in I'll flip the car up on its side to do final welding. Welding upside down is just too much of a pain in the neck. Of course I'll post pics when I can.
Also took a break from the back end to turn to the front. After much hacking on the Heidt's Mustang II suspension crossmember, the firewall and the floor, I now have the engine and 4L80e trans sitting where I want them and where I'll be able to get my driveshaft angles properly set. While the 4L80 is pretty long and I moved the engine/trans back a bit, the factory bench seat is still going to work fine. I've been playing around with the Suspension Analyzer program to figure out how I'm going to reposition the steering assembly to make this work with the repositioned engine. I have a couple of position solutions that will allow me to keep the rack and pinion with good steering geometry... now it is just a matter of figuring out how I'm going to make the bracketry to relocate the rack and drop the outer tie rod mount points. While a headache, on the plus side I should end up having re-engineered it to have less bump steer and better ackermann geometry. If the rack doesn't work out the other option was (and still could be) going back to the old steering box and just fabricating a new center link that will position the tie rods where they need to be. |
#416
My car has finally hit the ground and is running. The headliner from Ames is installed and the seats are upholstered. The interior trim parts need painted and installed, then the carpet door panels and seats can be bolted down. After a front end alignment, it will be ready for the road. Thinking about spraying a semi-gloss coat of clear paint on it. Also have a set fat and skinny tires on cragar s/s mags ready to mount.
#417
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
#418
All put together and a few shake down drives. A real tire fryer! Now I get to put it away till spring :-(
Exterior Shots 1: |
#419
Some more!
#420
Note my conversion to 66 GTO Rally Gauges & the Wangers and Beswick glove box!
