#121
Old 11-16-2012, 11:17 AM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Originally Posted by GTOLou View Post
I think Nitto makes the tires I want on the 17 rim.
(275/50/17 and 255/50/17 for a 2nd gen - Trans Am).
Nitto and Falken are the only manufacturers of 275/50-17's that I know of (unless someone else has brought out this size recently). I've been running them on my truck for years. Nitto NT450 255/50-17 fr & 275/50-17 rr. Not the greatest performance tires (I run drag radials 275/60-15 at the track), buit they have held up well over the years. I am no fan of Falken tires.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #122
Old 11-17-2012, 12:23 AM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I bought a set of the 17x8"s from YearOne today at the Moultrie Swap meet. But, they have the 4 1/4" backspacing. Will there be any problem mounting these on a 67 GTO? I don't have tires yet so, if these wheels will work what tires should I use?
  #123
Old 11-17-2012, 10:17 AM
quicksilver97ta's Avatar
I don't know the answer about the tires but I just wonder about the 4.25 BS, is that what they advertised or did you measure that?
  #124
Old 11-17-2012, 10:23 AM
  #125
Old 11-17-2012, 05:20 PM
john31s john31s is offline
I am kinda surprised that YearOne has kept a lid on these and no one has has them. I'd expect they were chinese made and usually the chinese will sell to anyone/vendor that'll buy.
I know there is an ebay vendor that has the 17 snowflakes - but I haven't seen them elsewhere.
Anyway - I need a new set of rims at some point and will probably buy the rallye II's. I like the 50 series tires and there are NOT that many of those out there. I don't want a 26" wheel/tire and most of the 40's are just too short. I think Nitto makes the tires I want on the 17 rim.
I believe these wheels are being sold by PY and Ames. Those Nitto tires you are referring to are Nt 450's and were a mediocre tire 10 years ago. If you want to get these Rally II's get the Nitto 555's on them with 40 or 45 series tires on them and lower the car. A 50 series would be to much tire anyway.
1970 Lemans 350/ TH350 ProTouring Madness
  #126
Old 11-17-2012, 09:00 PM
fyrffytr1's Avatar
They are advertised as 4.5" back spacing but the first run were tooled wrong and ended up with a 4.25 backspacing. The correct ones will be available this coming spring. I took these back to Year One today and got a refund. I told them I wanted to wait until the 4.5" backspaced ones come out.
  #127
Old 11-18-2012, 10:10 AM
The Champ's Avatar
John
The 555 and the 450 are available in a 255/50/17 (27.1" tall). Not all of us are looking for short tires (on the rear anyway)...
These are the same diameter as my current 255/60/15's - and I'm not looking for shorter tires with my 461 with 3.42 gears.
I've been looking at possibly switching to 17's and right now my only tire options (I want redlines) are the NT 450 and 555.
The 450 has the sizes that come closest to my current setup - that I like - with 225/50/17 (235/60/15) at 26" and 255/50/17 (255/60/15) at 27".
If I go with the 555's, I can still get my 255/50/17 for the rear, but on the front if I want 26" tire height I need to go to a 255/45/17 - and I don't know if I can stuff that under a '64 GTO. 245/45/17 might work - a little shorter (25.7) but wider than my 235/60/15. Currently my tire clearance is REAL tight.
My current rims are 15x7" factory with 4.25" BS - so maybe that extra .25" would allow the wider 17's...
  #128
Old 11-20-2012, 09:31 AM
Junkyard Dog's Avatar
I would look at the tires that come on BMW SUVs. They appear to have some sidewall to them in 17, 18, and 19 inch wheels, 26 to 28 inches tall.
Badder than old King Kong
-Jim Croce
  #129
Old 11-20-2012, 09:34 AM
When they are convinced there is a market for them.
It seems obvious to me that the market is better for the earlier style wheel than the one they are currently producing.
-Jim Croce
  #130
Old 11-20-2012, 04:55 PM
Moving back to the 17" Rally II's, for anyone who is running them, what brakes are you running with them? I'm trying to go with big brakes but I am concerned I won't be able to fit 13" rotors under them.
  #131
Old 11-21-2012, 02:39 PM
Nicks67GTO Nicks67GTO is offline
If you get those wheels mounted you gotta take some pics! Iv'e been looking forward to seeing these wheels on a 67' GTO. Are you going with a taller sidewall? I definitely would. I think the short wall 40 series stuff looks good on the firebirds but strange on the big cars.
  #132
Old 01-30-2013, 02:59 PM
67rstbkt 67rstbkt is offline
So has anyone run the Year One RallyII with larger brakes? I'm finding conflicting info on the subject. I think I would want to go with the 17x8 front, 17x9 rear on my 67 firebird and I want to use C5 brakes with Kore3 parts. Any input on this? Has anyone who has these wheels printed out the template on Kore3's website to see how much clearance there is?
If not, (and I know this might be a lot to ask) can someone who has them print out the template and check? I'm sure it would help out a lot of people looking at these wheels.
  #133
Old 01-30-2013, 05:25 PM
I have these wheels(17" YO Rally II's) and they are tiny on the inside. I initially bought the Right Stuff Retailing Signature Series Kit, but that didn't fit in the wheel. I measured tonight with some templates and it looks like I have 14.3"-14.4" inside the wheel which means none of the Kore3 brake kits will fit. You best bet is the Wilwood 6 piston 12.19" rotor setup. That is 14" across so it will fit, they also do a 4 piston setup on a 12.19" rotor but its 14.3" across which cuts it close too close. Only issue is the Wilwoods are a bit pricey.
John
  #134
Old 01-30-2013, 05:37 PM
John
Thanks for the response, even though it's not what I wanted to hear. I really like the look of these wheels but I also wanted to go with the C5 brakes (I already have the calipers). I guess I'll need to think about what I want to do. Thanks for the response.
  #135
Old 01-30-2013, 05:55 PM
One option I come up with was a 1LE brake swap, but that involved swapping over the b-body spindle. I haven't ruled it out yet, I'm just seeing where i can get my brakes with the addition of rear disk and better pads all around.
  #136
Old 01-30-2013, 06:00 PM
I've still got a few months to make the decision, so I guess I'll keep researching what's out there. Thanks for the info
  #137
Old 02-03-2013, 07:16 PM
mbwicz1 mbwicz1 is offline
Default Nitto Tire Size
I saw last month that Nitto has added a size to their NT450 line ('entry level high performance') which would fit some cars here...
275/50R17 27.8" diameter, 11.0 wide
255/50R17 27.1" diameter, 10.1 wide
225/50R17 25.9" diameter, 9.0 wide
It may not be the best of the best tires out there, but the 275/9" rear and 225/8" front would scratch my itch pretty well..... I'm not sure that I would want to run a 255/50 in front.
Mike
No Pontiacs in the garage right now.....
  #138
Old 02-03-2013, 09:45 PM
robscar's Avatar
robscar robscar is offline
The 1le brake swap is very nice, cheap, and pretty easy to do. I did it about 6 years ago. Big car spindles from Scarebird as he puts a taper in the ball joint holes so you can run stock joints.
  #139
Old 02-08-2013, 12:03 PM
Do you have any links on the swap? Been searching around and have not found much yet. Thanks
  #140
Old 02-09-2013, 08:47 PM
6 Grrrs's Avatar
Mike
275/50R17 has been available from Nitto for many years. I have run them on the rear of my truck for at least 11 years. I run 255/50-17 on the front.
Tod Hoffmann
2002 Honda VTX1800C
