Old 12-13-2012, 04:33 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Default Remote oil filter kits
Where is the best place to get one for a high pressure Pontiac race motor?
Old 12-13-2012, 04:44 PM
David Holmberg's Avatar
I've used one from Butler for 10 years, works great.
Old 12-13-2012, 05:58 PM
J.C.you's Avatar
J.C.you J.C.you is offline
on the circle track stuff i have been making my on, no10 braided line to filter housing of your choice. On stock blocks drill and tap for 1/2 NPT.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 12-13-2012, 11:24 PM
aaronman aaronman is offline
I use the System One mount & filter on both our race vehicles. Not cheap but also allows you to monitor your filter for engine issues.
Old 12-14-2012, 12:51 AM
R 70 Judge's Avatar
This looks like a nice set up. I don't know anyone who has run it though.
Complete kit for $320
http://www.nitemareperformance.150m.com/oil.html
James
1970 Trans Am
Old 12-14-2012, 01:50 AM
Old Man Taylor's Avatar
I aso converted to the System 1.
Old 12-14-2012, 08:11 AM
I gots an old remote kit with the thick gray rubber/weave lines. Is a change to 1/2" copper lines with flare fittings a wise, popular move?
Old 12-14-2012, 08:27 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
I got my system1 oil filter from Summit and got the mount from Jerry Bickel,it was the same set up Aaronman runs.He always has put me in the right direction.
I figure the oil filter has already paid for itself twice now.
http://www.jerrybickel.com/bottle-mo...t---cv746.html
http://m.summitracing.com/parts/sof-211-510571-1
................and no the CV-746 isn't yet another port Bill came out with....
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 12-14-2012, 08:57 AM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
I would say that hard line would be a big no-no unless the filter housing was mounted to the engine directly and there was no flex to work harden and break the tube.
The other problem is that 1/2" tube is only 1/2" OD less twice the wall thickness. All of the hose is measured from the ID, and the typical-10 line is 5/8".
I know that you know this stuff, but I would hate to see anyone use hard line and eventually break it and blow oil underneath the tires.
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 12-14-2012, 09:29 AM
J.C.you's Avatar
Default housing
here is the filter housing on the circle tracker. Joes HP6 series. Nice billet piece. On a couple of street remote setups I used the moroso units for the 1049 Napa filters.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-14-2012, 11:50 AM
I have a system 1, but I actually took it off and started running the standard K&N filter. Oil pressure seemed to be more stable during hard braking in the shutdown. I might try it again some day.
Old 12-14-2012, 01:38 PM
S/st 54's Avatar
[QUOTE=adam woodmancy; Oil pressure seemed to be more stable during hard braking in the shutdown. I might try it again some day.[/QUOTE]
Hard braking in shut down......hmmmm let me try this...when Adam gets a win light he hits brakes hard enough to take the earlier turn around so he can get back quicker to start cooling car down...and gets so many win lights he sees oil pressure the same time his win light comes on on the gaurd rail.....?????? Am I close
Note to self : stay away from that ringer!!!!
Old 12-14-2012, 04:03 PM
Excellent. KNEW there were good reason to NOT do copper, just forgot, so I posted such.
Old 12-14-2012, 05:11 PM
Lol. I'd be a liar if I said I hadn't done that before once or twice.
But only when double entering... The old poncho stays pretty cool. The converter is a whole 'nother story though... Lol. The day I won my first Wally I burnt the converter up. Made it to the final in sportsman, lost on a breakout, then had to come right back around and run the last 3 rounds of pro. By the end of the day, I was dialing up about .05 per pass and having to stall the car higher and higher as the converter left the building. Lol. Not to mention, we had to steal the battery out of the dually because mine was so dead the car wouldn't start. It's days like that we remember forever... Lol
