The body doesn't look too terribly bad actually....except in the dash area. Maybe I'm not seeing it right or I missed it somewhere if it was mentioned but it looks as if someone actually cut the metal dash out of the car? That will be problematic but nothing that can't be overcome. Replacing all the underdash stuff, assuming you didn't pull it all out yourself, will be like trying to put a puzzle together without a picture of what the completed subject is. It can be done but you will need a lot of references there. That's where these forums will be a ton of help.
It does have an Oldsmobile engine. From the blue color, I'd guess it came out of a 2nd Gen Trans Am. I'm with Ben. I like to keep as much of the original car in place as practical and only replace what's no longer usable. You'll find as you go along that reproduction parts sometime leave a lot to be desired when compared to NOS factory equipment or properly restored original parts from the car.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 01-20-2013 at 12:50 AM. |
The thermostat housing is angled wrong to be from an F-body. Also the cruise control diaphragm is '73-77 Olds only vintage and won't fit on an F-body with a shaker setup, same with the alternator brackets (what ones are left). Also has A.I.R. tubes. I'd speculate it came out of a '75-78 Olds something or other. Easy enough to look up the codes and figure it out though.
My opinion is to be realistic and put it all back together, cleaning and painting as you go doing everything yourself if you have the ability. Paint it in your driveway or garage with cheapest materials available yourself. Put a Pontiac motor back in it if ya have one. Get it in running and driving condition and enjoy it as a "driver". Unless you are independantly wealthy and have ALOT of time, this is the way to go for a common Lemans. Should only cost maybe a grand if you are resourceful and you'l be enjoying it in a couple months. This is what I do with this class of car in simlilar condition. Then I drive em for a year or two and sell them or trade em up for another car. Good luck. What I described is an enjoyable way to experiance the classic car hobby and you don't lose your ass in doing so.
Catalemans 65 Lemans 4dr 326/2speed 67 Lemans 2dr 400RA/TH400 |
I also did my first restore when I was around 25 years old (67 Firebird). In some ways it was easier- parts were still available in local junkyards, etc. But in some ways it was harder- no internet forums for advice and the supply of restoration parts was much more limited. But, and this is big- I also had already graduated from college, had a good-paying job, and had my own house with a real double garage.
If I remember I put about $15K over a period of a few years into that Firebird to get it really nice, doing most everything myself including bodywork/paint and the engine build, but that was 25 years ago. Fast forward to now. I just recently finished my 69 Lemans vert. Well, never really finished but now more in tinkering and maintenance mode. This one cost me over $40K to do though I did farm out the engine build, and exterior paint and bodywork to others which added some to the cost. I kept a running total which is attached just so you can see how it quickly it can add up. Keep in mind that I started with a pretty functional driver in much better shape than the car you are working on. As for getting your money out of it, forget that. I look at restoring a car as a hobby, and all good hobbies are expensive. If the "restoration adventure" is worth it to you, and the car is what you want and you have the cash needed then go for it. But if you just want to own a classic car then go buy one because its a whole lot less expensive than doing one yourself. As for how to do it you are already getting some good advice here. I prefer to do mine in phases instead of tearing the whole car apart and rebuilding it all at once. Less intimidating, helps spread the cost, and I get to drive in-between phases. Lots and lots of pictures, tag and bag parts, keep a running notebook with sketches and notes. Use original parts wherever possible. Sounds like you got a bit ahead of yourself with the tear-down but suggest that you stop now and organize everything the best you can before doing anything else. If it were me I would concentrate on cleaning it all up and reassembling, fixing mechanical/electrical systems as I went along to make it road worthy. Forget about cosmetic details for now. Just getting to this point will take a bunch of time and money. Then drive it for a while and plan next steps. As for the engine there are plenty of us that have perfectly good running Pontiac 350's without a home. You should be able to find one very cheap or even free with a little hunting around. If you want to go fast I would make a high-perf Pontiac engine swap part of a later phase. Remember that building for hi-horses involves more than just the engine. The trans, rear end, suspension, cooling system, etc. all need to be up to the task which adds to the cost and complexity.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
That Lemans looks to be a decent car, to restore. My GT-37 appears to have more rust issues than this car. I too plan on restoring it one day. Just gathering all parts that I need, while keeping it a driver. Most importantly having fun with it. While the parts are being collected. I would also say pictures, labeled boxes, bags etc will help in the restoration process.Years ago my son and I redone his Camaro , we labeled items, took lots of pictures. That really helped us to put it back together years later.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() Last edited by 2002Z4CSS; 01-20-2013 at 01:17 PM. |
