Old 02-01-2013, 11:14 AM
FSJplumcrazy's Avatar
FSJplumcrazy FSJplumcrazy is offline
Default stupid expanding foam
I have to firm up under a new bathtub and shower and the cans of expanding foam I have has instructions that the can is to be inverted to get the stuff out.
Is there some canned foam the sprays upright so I can shoot it up from the basement between the tub and floor or am I screwed and just have to punch a hole in the new walls?
Wayne S
Nothing is impossible, impractical maybe, but never impossible.
1966 Le Mans Convertible STATUS: *In Progress*
389 (sixty over)/200-4R/10 Bolt (3.08 for now)
My other ride is a 71 Jeep J4000 Pick-up Truck with factory Buick 350/Th400
Old 02-01-2013, 11:54 AM
stags's Avatar
stags stags is offline
Not sure if any work top-up. Even the large cans that screw into the applicator guns want to be upside down. I've used a length of clear tubing to loop up when needed. That way you can monitor the flow. Just don't stop for too long. Good luck. Mark O.
Ain't as good as I once was, but I'm as good once as I ever was.
Old 02-01-2013, 11:56 AM
Pearlbluebird's Avatar
Pearlbluebird Pearlbluebird is offline
They are more money but you can buy a spray foam tank similar in size to a barbaque tank that will come with a small wand for your application.
A second class drive is better than a first class walk.
Old 02-01-2013, 01:23 PM
jetallman's Avatar
jetallman jetallman is offline
The foam cans I use are sprayed upright, make sure to fill tub with water I spray foam under mine and forgot one time and had a jucuzzi lift up.
The foam cans I get are large gap type I believe Dow, get them at local lumber yard.
69 455/4-sp windward blue under major restoration
69 400/400 waiting for resto
Old 02-01-2013, 01:28 PM
sdbob sdbob is online now
The shower stalls and bathtubs we installed we used cement in basements and wood in up stairs installations for support.Sometimes you have 2 people standing inside. Never used foam. Will the high density stuff compress?
Old 02-01-2013, 02:59 PM
Ed Fitzgerald Ed Fitzgerald is offline
Default Spray foam
Use the low expansion type and put it in in several applications. Ie. if you are filling and need to use 3-4 cans then do it over 3-4 applications. 1 can= 1 application.
Old 02-01-2013, 03:15 PM
The Boss's Avatar
The Boss The Boss is offline
We use this stuff - mix it up in a 5 gal pails, slop it out and around, set the tub and stomp in it until it's set where you want it. Once dried it's perfectly solid and won't give a fiberglass tub that hollow feeling.
http://www.usg.com/usg-structo-lite-...t-plaster.html
And go racin' in the street.
Old 02-01-2013, 05:09 PM
You can always use it the way the previous owner of my car did...To fill up the rust holes in the roof. Apparently, it sands very nicely...
Old 02-01-2013, 06:27 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Just go get some clear tubing to the length that you need. Then you can hold the can anyway that it needs to go.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 02-02-2013, 12:06 AM
72pontiac's Avatar
72pontiac 72pontiac is offline
they do make great stuff that sprays upright i think its the light blue can. for doors and windows.
Old 02-02-2013, 10:03 AM
Cammer-6 Cammer-6 is offline
doors and windows stuff is normally minimal expanding
as others have already said,just use a longer tube
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-04-2013, 03:55 PM
GT182's Avatar
GT182 GT182 is offline
LOL... never use that yellow expansion foam around doors and windows. Especially if you want to open them again. Don't ask how I know.
The white foam is the good stuff, but not for under your fiberglass tub and shower unit FSJ.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
