James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Blueghost--what kind of master cylinder are you using and how did you get it to hang so level? Project is looking good!!!
The master cyl. is for a 67-68 firebird manual brakes. I wanted it to look some what original. I had a friend of mine make me a wedge out of a piece of alluminuim and I mounted my master cyl. on the top bolts instead of the bottom ones for more clearance for the lines and so I could run them inside of the fender wells so it would give that orignal kind of look. Worked out pretty well. Theres more about it in the earlier pages on this sight and pictures too. GT. |
I started building the exaust I'll get some pics up soon.
GT. |
Nice setup! Did you elongate the through hole in the firewall and is the pushrod at an angle! John
I used a hole saw and drilled another hole above.
It actually is about a 1/4 inch into the lower hole. The rod to the master cyl. is straight to the brake pedal with good alignment as there were two holes on my brake pedal. So the geometrie is right on. GT. |
Here are some shots of my 63 coming together. Puddle is from radiator burping! Still need to make decisions on interior and wheels/tires! John
Art Morrison triangulated coil over, Ford 9", 700R4 |
Car looks sweet, I like the color to. Have you had it out for a drive yet? GT. |
