#461
Hers some more.
GT. |
#462
Car looks sweet, I like the color to. Have you had it out for a drive yet? GT. |
#463
Thanks, I have just over 150 miles on it. Been optimizing position of shifter before final buttoning up of floor boards. It handles pretty darn good, so far! John
#464
Got some more pictures of the exaust.
GT. |
#465
The exhaust looks great. Are you MIG welding? Also, what are you using to cut the pieces? I will be doing the exhaust on my '60 Catalina sometime in the next few months.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#466
Yes I am useing a mig and a chop box to cut the tubing.
I used my buddies ban saw to cut the 90's for the X-pipe. I think I'm going to need more elbows when I get to the rear for the tail pipes. This is starting to get a little costly. GT. |
#467
Well I've got some more done on the exaust.
This is getting old laying on my back and It's Getting pretty darn exspensive too. Heres some more pics. GT. |
#468
I haven't posted for a while. It is getting close. Tonight I turned the fuel pump on for the first time and checked for leaks. Of all places for a leak, the plug at the rear of the pressure regulator leaked. That is now fixed. The regulator is set to 4.5 LBS. I looked down the throat of all three carbs, no leaks there.
The exhaust is on also. Here are some pictures. |
#469
Daaaaaanngg That baby's looking sweet.
Very un-suspecting, Your gona hurt someones feelings when they pull up beside you for a run.LOL Nice job Rad. GT. |
#470
We started the engine for the first time on Saturday. I went back to the garage today to adjust the transmission linkage so that the transmission and gearshift agree. Did find another slow gas leak at the front and center carbs. We decided to let the engine cool down, then we will go over all of those line connections. Here are a couple of links to the start-up. A friend (ford guy) mislabeled the engine size as a 383. He is supposed to correct that to read 389.
http://www.youtube.com/watch?v=KNBe5AjUNjg http://www.youtube.com/watch?v=5MnCD...ature=youtu.be |
#471
Here are my two '63 projects. The black car is a sport coupe with 3-speed manual and the white one is automatic.After checking the white car out, and buying a battery. it fired right up and purrs like a kitten.
Plans are to possibly make the white one a driver after making it road worthy, while playing with the black one. It needs a lot of TLC as you can see, but is solid other than the roof. As I've said elsewhere in this forum, I'm seriously considering swapping a C5 Corvette 6-speed transaxle and rear suspension into the black one to keep the same basic layout, with a Pontiac engine. This is the first time I've been around these engines, so it will be a learning process for me. Thank goodness I found this forum and the Little Indians website. Any and all help/suggestions will be greatly appreciated.
#472
Nice-looking Tempests!
They will be a lot of work, but a lot of fun, too. IMO, don't even think about straightening the roof on the black one---just weld a straight roof on. I spent a long time on my '63 racecar straightening the left side of the roof where it had apparently been run under a tree branch (or a bridge abutment!). If I'm faced with that again, I'll just replace the roof. Normally, a roof is the one part of a car least likely to be damaged, so it shouldn't be too hard to find a replacement.Jim
#473
I had a body man come over and actually lay hands on the roof and he said he could fix it for $1500. I found another roof at my local yard for $225. Not sure of the cost to install it. Either way, it will be a lot of work, but other than the roof, a solid, complete car.
#474
It sounds like you got the perfect car. If the roof hadn't been bad, someone else probably would have gotten the car a long time ago. But by tackling one big fix, you finish with a nice, complete car at a fraction of the price. Good luck with your new projects. Jim
#475
The Tempest wagon is up and running again.
Just have to bleed the brakes and will be driving it this weekend. Might have to go to the track just for some where to go. The 62 Tempest coupe will be going real soon also. Yeehaaaaaa!!!!!!!!!!!!!!!!!!! GT. |
#476
Well I've been out driving the tempest wagon.
Man this thing drives like a new car except for your normal rattles for a 50-60 year old car. LOL What a blast to drive , It's gona be my daily driver for the summer. Still a few things to do but it's all stuff I can do in between driving it. And the fun continues. GT. |
#477
I haven't even touched my car since January. I suck
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#478
Well get on IT!!!!!
We ain't getting younger ya know. I've been driving the wheels off of the wagon just sence last night. Man this thing gets killer milage. GT. |
#479
Heres some more pictures of the 62 tempest.
Got ht drive shaft loop done and the shifter box. Got to pull the motor out for the last time so I can mount the fuel system move one brake line for header clearance and install the clutch assm. Should be driving it before the end of the month. GT. |
#480
Was working on a 326 for one of the wagons and discovered a 4 foot new hire. I wondered why nothing was chewing the rat poison bags lately. Guess I owe him a raise.
