Old 05-12-2013, 09:36 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default Purple Power beware!
I bought some of this degreaser at Walmart for around $4 a jug. It's advertised as a multipurpose degreaser and I used it on a few concrete driveway stains. Works great for that.
I had an extra jug laying around so I thought I'd try it on some greasy engine and suspension parts.
Bad mistake! This stuff is not for painted parts. It eats paint just as easily it dissolves grease, leaving painted parts white/oxidized.
Beware what chemicals you use on your cars. Some of this stuff is really crazy abrasive.
Is the safest degreaser for engine/suspension parts still Simple Green?
Old 05-12-2013, 12:08 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I spray Simple Green directly onto my paint to soften the bugs up before driving it through the car wash. I also soak my Rally IIs down with it to combat the brake dust at the same time. It goes on straight and it has not damaged anything yet. Oh, I forgot the other use; I spray it on the sides of my car especially by the rear quarter windows to loosen the industrial strength adhesive commonly known as dog slobber before washing also!
Karl
Old 05-12-2013, 12:13 PM
Here's another news flash for you....That purple stuff will turn aluminum very dark, almost black and you can't polish it out (I don't think so anyway). It seems to actually convert the color..
It's great stuff and I always keep some on hand.... but you have to test it on anything you haven't tried it on before. I think the big issue is that it contains Lye and aluminum does not like lye.
Old 05-12-2013, 12:21 PM
Firebob's Avatar
Firebob Firebob is offline
Sounds almost like one of the rust convertors. That's pretty cheap is it works for that.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-12-2013, 01:36 PM
Oven cleaner turned an aluminum Kart motor dark when I use it also as a degreaser.
Old 05-12-2013, 02:03 PM
There are two jugs, one in white called "purple power" about $4, and another heavy duty version in a purple bottle, about $7. Both are from the same manufacturer and look like the same chemical. Nasty stuff for engine bays. I would only use it on driveways or parts you want to repaint.
Even Gunk brand foam aerosol engine cleaner is not as harsh.
Old 05-12-2013, 03:31 PM
Sirrotica's Avatar
If you dilute it it is no where near as harsh, full strength it is pretty effective to remove most anything.
I know none of us ever does this, but the directions tell you to dilute it for most automotive uses although it does say full strength for automotive engines. I know, if diluted works, then full strength will work better,right?...................LOL
For most automotive cleaning uses it says 10-1, also says to test it on the surface before you use it full strength and be careful of aluminum.
I've been using it for cleaning most anything in the home or car for at least 5 years, if you have white or light colored linoleum or tile it will brighten it up better than anything I've ever used. We used to have white linoleum in or kitchen and my wife couldn't believe how much of the dingy stains that it removed. The floor cleaners and household cleaners she tried worked as well as straight water, Purple Power full strength made it white again.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-12-2013, 04:15 PM
68bird400HO's Avatar
Purple power works great as a paint stripper on plastic parts. It is the best product I have found for that.
Old 05-12-2013, 05:07 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Were you able to neutralize the white after finish?
Old 05-12-2013, 06:08 PM
Not yet. Tried some soap and water but that didn't work. This stuff is strong. I would not use 1:1 again on car parts, no mater what the instructions say.
Old 05-12-2013, 06:18 PM
aktattoo's Avatar
aktattoo aktattoo is offline
rundown on main ingredient
ether (DGBE) is a type of glycol ether. It is primarily used as a solvent in coatings, inks, cleaners and specialty fluids, or to produce diethylene glycol butyl acetate.1 It evaporates slowly and is completely water soluble.2 Dow sells DGBE under the trade name Butyl CARBITOL™ solvent. See Product Uses, Product Description and Manufacture of Product.
may react with bases, aluminum and oxidizing materials. ETHYLENE GLYCOL MONOBUTYL ETHER(111-76-2) is liable to form peroxides on exposure to air and light. ETHYLENE GLYCOL MONOBUTYL ETHER(111-76-2) attacks some forms of plastics, rubber and coatings. .
and toxic of course...
1970 Bonneville Convertible
Old 05-13-2013, 05:36 PM
69Farburd's Avatar
69Farburd 69Farburd is offline
I have some bathroom floor tile that is rust stained. Nothing has worked on it. Think this stuff would work?
Old 05-13-2013, 06:25 PM
Sirrotica's Avatar
If this stuff doesn't get it out nothing else will. I've used it on linoleum, tile and terrazzo floors and it has always done a great job. Test it before you slather it on the floor though so you don't end up replacing tile. Make sure you have plenty of ventilation the stuff in a small area will make you cough if you get a good dose of it full strength.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-13-2013, 11:04 PM
I assume you've tried CLR? .... The 'R' is for rust.
Old 05-15-2013, 12:37 AM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
'Purple Power' has been around at least 30 years or longer. At least that's how long I've been using it. It was called 'Cartex' around her back in the late 70's and 80's. And yes, you MUST dilute it, and never get it near any wheels that don't have a clearcoat on them.
Old 05-15-2013, 03:00 PM
Another one to avoid using on painted/coated parts is Mean Green. IF you have a Zep dealer, they make an aircraft wash that is FAA/DOD certified as well as Boeing and McDonnell Douglas certified.. It will not corrode metal and will remove most greases, oils and carbon soot.
Dr. Thomas Sowell
Old 09-05-2014, 08:22 AM
I went back to Simple Green. Might take a little longer to dissolve grease but seems safer on parts.
Old 09-05-2014, 09:28 AM
Don 79 TA Don 79 TA is offline
dang....
i learned that purple power lesson back in the 90s when it came out
NOT fun when you have a nicely painted engine
it is great for degreasing though, but need to use caution
Old 09-05-2014, 05:36 PM
ponjohn's Avatar
Will it deteriorate rubber hoses etc?
Old 09-05-2014, 05:51 PM
Dick Boneske's Avatar
Castrol Super Clean works very well for heavy-duty cleaning jobs. It is very harsh when concentrated, but can be diluted for lighter jobs. You would not want to use it full strength on painted or plastic parts, but diluted would be OK.
Super Clean was formulated to clean the parachutes on drag cars. I've used it with success for many years.
BONESTOCK GOATS
'99 Bonneville SE Sedan
