Old 05-19-2013, 07:03 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Angry Oil stain removing driveway stains ?
Daughters T/A has a slight oil leak that appears to be the rear oil seal.
Engine is a never rebuilt 71 455 (sans timing chain/gaskets), so it's to be expected.
That being said anyone have any tips on removing oil off the driveway ?
I tried Kitty litter and scraping my shoes across it, which helped but not as good as I'd like.
Used my electric pressure washer (it's a cheapie) & it's still there.
Any ideas - ?
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 05-19-2013, 07:06 PM
sleepy's Avatar
sleepy sleepy is offline
concrete? muriatic acid.
Why is he not suspended?
Old 05-19-2013, 07:24 PM
70 bird's Avatar
70 bird 70 bird is offline
X 2
Old 05-19-2013, 07:34 PM
rexus31's Avatar
rexus31 rexus31 is offline
Believe it or not, I've had pretty good luck with Brakleen.
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior
1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top
Old 05-19-2013, 07:42 PM
400 4spd.'s Avatar
Wet it, pour some powdered laundry detergent on it, and lightly wet it again so it gets pasty looking. After a half hour, I scub a broom across it and rinse, usually does the job.
tom s tom s is offline
2x brake cleaner
Old 05-19-2013, 07:47 PM
62cat's Avatar
62cat 62cat is offline
Default oil stain
try powdered tide. i used on my driveway for some big stains soaked most of it up.i left it on there a couple days then added some water scrubbed then rinsed. came up real clean.
Old 05-19-2013, 08:07 PM
Any ideas - ?
Concrete or asphalt?
Old 05-19-2013, 08:10 PM
Both; stains in the driveway & garage
Thanks for all the advo guys -
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-19-2013, 08:23 PM
Alvin's Avatar
Alvin Alvin is offline
Wink Try this
Fast Orange hand cleaner. Squirt on the stained area, use a old nylon scrub brush to work it in...let it set per the instructions, then wash it away.
It works best here in the heat of the summer...allows the acid to work faster in my experience.
You results may vary.
Old 05-19-2013, 08:37 PM
pont3 pont3 is offline
Just go to walmart and get some of the cheap carb cleaner. Just spray it and wipe away the stains. Or, as others have said, brake cleaner.
Old 05-19-2013, 10:39 PM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Thumbs up
X2. Also had good luck with liquid laundry detergent and a stiff broom.
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 05-19-2013, 11:35 PM
LeighP's Avatar
LeighP LeighP is offline
A friend of mine spilled concentrate pool chlorine in his drive...man, that cleaned the concrete real nice.....lol.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 05-20-2013, 08:16 AM
jhann42 jhann42 is offline
Default Driveway
I've used Gum Cutter. It's more powerful than carb cleaner & a lot more powerful than brake clean. Just spray it on concrete and wipe it off. Not sure about asphalt. It may dissolve it?
Jon
Old 05-20-2013, 08:32 AM
elefantrider's Avatar
elefantrider elefantrider is offline
See my other post on Purple Power, available at Walmart for around $4.
Old 05-20-2013, 12:26 PM
marbs marbs is offline
I've had good success using oil dry & rubbing with a brick on concrete.
Old 05-20-2013, 12:44 PM
Alvin's Avatar
Wink
I remember that thread...good one. Linky?
Old 05-20-2013, 02:01 PM
http://forums.maxperformanceinc.com/...d.php?t=727574
Old 05-20-2013, 03:11 PM
GT182's Avatar
GT182 GT182 is offline
Try Softsoap.... the hand soap you have in your bathroom. That stuff will take the toughest grease of yer hands so it should work on cement driveways too. I've used to get grease out of my work jeans and t-shirts too.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-20-2013, 03:17 PM
Alvin's Avatar
Wink
Same here...I use Fast Orange on greasy clothing worn during working in cars, etc. Spot and pre-cover stains with soap...amazing how zero evidence of grease after washing.
