Old 02-25-2013, 11:57 AM
gitgo gitgo is offline
Default what to do
working on 63 lemans . need to know a few things. who makes a good radiator for it ? also need to know where to get a gas tank for the stock location ? any help ?
Old 02-25-2013, 01:21 PM
Radman's Avatar
Radman Radman is online now
US radiator has several choices that will fit. With them you have a choice of 1,2,3,or 4 row radiators. Also check the Ames catalog, they have a dedicated Tempest catalog.
Old 02-25-2013, 02:17 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default radiator
I used a Griffin aluminum radiator for my 400 ci conversion. The size is 19" x 26" and fit with minimal bracket/radiator mods. The cost was around $150. I even modified a stock 326 fan shroud to fit.
ID:	314368   Click image for larger version
Old 02-25-2013, 03:31 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
I did a similar thing as C5Farmer only I think I used a "Northern Radiator" ... about the same price ... Made in the states. Make sure that you get one with a drain petcock at the bottom! John
Old 02-25-2013, 08:24 PM
Thanks for the reply.
Old 02-26-2013, 09:46 PM
heater63's Avatar
heater63 heater63 is offline
Gas tank, good luck. I was able to use a 64 GTO gas tank in my wifes 4 spd with some mods on the straps. it was okay and got her down the road but not great. Got another okay one for a 63 and having it lined and changing it back. Someome here on this forum tried it with an automatic and it didnt fit too well because of the torque converter
Looks like I have a almost new tank for a 64... GTO for sale
"If you aren't first, your last." Ricky Bobby 2006
Old 02-26-2013, 10:04 PM
c5farmer's Avatar
Default Gas tank
Your best bet is to find a good tank from a 63 and use it. I have heard that an early chevy II tank will fit (it is a little narrower), but requires changing the filler tube to the tempest position. Or find some place like this and get your tank redone:
http://gastankrenu.com/
Old 02-26-2013, 11:30 PM
Default Gas Tank
Just realized you need a gas tank also. I have one up in my rafters that I'm getting tired of looking at, since the mechanical part of my 63 is almost done. Has the filler tube and even a gas cap. PM me if interested? John
Old 06-13-2013, 10:01 PM
boodlefoof boodlefoof is offline
I'm not sure whether it will work with the factory transaxle setup, but I just bought a tank for a '71-'72 Ventura (part number GM46C, also listed at Summit Racing as RSD-AFT7104) to use under my tempest with a Ford 9'' rear axle conversion. It only cost $140 delivered. It looks like it is going to fit under the trunk floor and between the frame rails very well.
To mount, it uses two straps running fore-aft. I happened to have a pair of extra trunk floor supports/strap mounts that look like they are going to fit perfectly to mount the straps to. The tank also does have a long welded-on filler neck that I am going to have to shorten to mate up with the Tempest's fill tube.
Not a simple bolt-in, but perhaps a good option for someone looking for something sort of stock looking that will fit under there.
Old 07-24-2015, 05:26 PM
Default need help still
after buying a US rad my car still over heats.I call US rad an ask if this the right rad? I am told not with a 455.Now what rad do i buy?
Old 07-25-2015, 12:14 AM
c5farmer's Avatar
Default Tempest guys radiator
contact roger rosebush at the tempest guys. He is making a direct fit radiator that cools over 500 hp. Rogers old company was BeCool radiators. He knows how to make them.
Old 07-25-2015, 01:34 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Also,, make sure the divider plate for the water pump is clearanced correctly, that the fuel mix isn't too lean & timing is correct. All will cause over heat issues.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 07-25-2015, 04:00 PM
I clearance the water pump.then i called us rad.They told me my rad was to small.That is why I am looking for a rad.
Old 09-09-2015, 11:57 AM
rdtripn_rte66 rdtripn_rte66 is offline
Little Indians members get a discount thru Roger Rosebush's radiator company. He can help you. 63 gas tanks are a 1 yr only item. PM me or Call - for his number if u cannot find it.
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
