Old 06-18-2013, 11:39 PM
roflo619's Avatar
roflo619 roflo619 is offline
Default Lowering Coil Springs for 1965 Pontiac
My '65 Catalina needs a suspension refresh. OPGI has 3" low profile coil springs for the front, but doesn't list 3" coils for the rear on a 1965.
Looking at my GM Interchange Manual, it shows that 1961-1965 Pontiacs all used the same part interchange number for the rear coil springs.
Does this mean that I can use 3" rear low profile springs listed for a 61-64 Catalina on my 1965 Catalina?
Please help!
Old 06-19-2013, 12:42 AM
66bonne's Avatar
66bonne 66bonne is offline
http://www.coilsprings.com/
Can't answer your question but if you need springs, lowered, stock or whatever, these are the guys to use.
Jim
Old 06-19-2013, 05:44 PM
roflo619's Avatar
Originally Posted by 66bonne View Post
Thanks for the tip. I'll check 'em out!
Old 06-20-2013, 03:37 AM
If you put 3 inch lower on the front then you will want 2 inch lower on the back. the front & rear springs require a different spring length so if you put a 3 inch lower on all 4 you would be 1 inch lower in the rear & 3 inchs is going to make you drag the ground now. Literly. Drag the ground. That is going to be to low for that car.
Old 06-21-2013, 11:52 AM
roflo619's Avatar
rexs73gto, I don't know if you can see my sig pic, but I'm already at 3 and 3 and driving just fine--slammed to the ground yes, but totally driveable. It has 3" low profiles in the front, and cut and heated coils in the back that in all honesty is more than 3" drop at this point in time. Both were put in a long time ago.
To get some ride quality back, I actually wanted to put low profile coils in the rear and new shocks all around, hence the reason why I was asking if 3" drop coils from a 61-64 Catalina would work on my 65.
The Following User Says Thank You to roflo619 For This Useful Post:
Old 06-21-2013, 03:41 PM
As far as the coils I think from looking at all the books i have the frame & the rest of the suspension is different then the 61-64 style frames so looking at it from the books they coils from th 61-64 won't work. Are you having a problem finding the correct coils for your car???. If that is the case you can , if you have call your local frame front end shop & most of those shops have access to special made coils , which aren't much more then buying them right off the shelf. Were lucky where I live we have a shop that sells special made coils & leaf springs. They've been in business for 40+ years & can make anything you would need right in there shop. The shop is in South Bend IN.
Old 11-25-2024, 09:01 PM
xWIIIx xWIIIx is offline
Hey buddy quick question. Did you had to change the shocks to be able to install these 3” shorten coils?
I joust got a quote from that company somebody referenced earlier in the conversation. 3” shorten 30to35% stiffer. Just under 700$ for all four
Old 11-26-2024, 10:46 AM
78w72 78w72 is offline
This thread is 11.5 years old & the member you quoted hasnt been active for 8 years. Probably best to start a new thread with any questions you have.
