Old 07-15-2013, 09:46 AM
Help you out a bit John.
If you take a typical E-head with the pushrod hole in the normal location and add a brass sleeve to the hole, you get Mike's head. His head is ported to the edge of the brass sleeve insert.
"There are tubes for the pushrods that cuts into the side number maybe .80 or so. more at the bottom"
If you are friend's with Vic Edelbrock, like Jim Butler was, and can get E-heads provided to you WITHOUT the pushrod hole drilled, you can then put the push rod where you want it, (using a shaft system), and you do not need the brass tube.
The head gets wider because you were able to drill your own location in the solid casting material vs do a "work-around" with the brass tube insert.
So yes, MIKE MAY NOT HAVE A WIDE PORT HEAD. He MAY have a Ported Normal head.
He might still be running a shaft system but the offset will be restricted by the head and brass tube location.
Tom Vaught
Old 07-15-2013, 09:58 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
you should enter tom s n/a race since your going 8.79. you would be right there.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 07-16-2013, 01:20 PM
john marcella john marcella is offline
Tom Vaught
Tom , Mike had a stock set of heads already, I welded the push rod holes and put them were they needed to be for the rocker offset that he has. Its only a .400 offset.
Did you really think you needed to tell me that info? If so you really have no clue about the things I do. And don't take that bad, its not meant that way.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 07-16-2013, 01:32 PM
GTOGEORGE's Avatar
Nice heads!
John, one of Toms 15,000 informative posts!
GTO George
Old 07-16-2013, 02:57 PM
mike leech's Avatar
mike leech mike leech is offline
ya i think johnta1 was who tom was talking to. LOL
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 07-16-2013, 03:18 PM
LOL
Well , sorry Tom. My bad. I guess its a good thing I wasn't a dick in that post.LOL
John Marcella
[email protected]
ph. 248-259-6696
Old 07-16-2013, 07:10 PM
Ron H's Avatar
Ron H Ron H is offline
LOL
Even when you are not being one you can still be taken as a Richard Head!
Make anymore passes this past weekend?
Mike, I bet that paint job is turning some heads.
Wish I could be at Norwalk. I think this years lineups should be one of the best ever.
68 Firebird
Are you running with the wind or breaking it?
