Old 07-14-2013, 02:57 PM
I roughly calculated that it was in the real 1.3" range so I need to recalibrate my "Thumb Standard" a bit. Of course Leech has a Big Thumb.
Tom Vaught
Old 07-14-2013, 11:19 PM
Dragncar Dragncar is offline
Mike, dont you have 360ish WPs?
What exactly is that a pic of ? Its not a head, is it some sort of template ?
Mikes not going to give me the bird, we get along just fine.
You sure have that thing rolling. Today at the track I raced a 8.30 Bird (BBC) in Super Pro. I looked back in the rear view mirror 2/3rds the way down the track and it looked like he was standing still, way back there. Thought he had a problem. Then he flew by me the last 10 feet like I was standing still.
Wish I had that kind of top end speed. 11.18 @ 117 to a 8.30 @ 152
Old 07-14-2013, 11:28 PM
mike leech's Avatar
mike leech mike leech is offline
He lifted on ya! big time, his MPH shoulda been 160 + for the et. Thats a cut out of the port when i make the intake gaskets, Cant get any more accurate than that. If anything it stretches the material a fuzz when i tap them out.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 07-15-2013, 07:30 AM
I thought these were wide ports?
Old 07-15-2013, 08:38 AM
mike leech's Avatar
those are!
EHTTFMF!
Old 07-15-2013, 09:46 AM
Help you out a bit John.
If you take a typical E-head with the pushrod hole in the normal location and add a brass sleeve to the hole, you get Mike's head. His head is ported to the edge of the brass sleeve insert.
"There are tubes for the pushrods that cuts into the side number maybe .80 or so. more at the bottom"
If you are friend's with Vic Edelbrock, like Jim Butler was, and can get E-heads provided to you WITHOUT the pushrod hole drilled, you can then put the push rod where you want it, (using a shaft system), and you do not need the brass tube.
The head gets wider because you were able to drill your own location in the solid casting material vs do a "work-around" with the brass tube insert.
So yes, MIKE MAY NOT HAVE A WIDE PORT HEAD. He MAY have a Ported Normal head.
He might still be running a shaft system but the offset will be restricted by the head and brass tube location.
Tom Vaught
Old 07-15-2013, 09:58 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
you should enter tom s n/a race since your going 8.79. you would be right there.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 07-15-2013, 04:15 PM
mike leech's Avatar
at 3330 i am. at 3522 not so close anymore...we'll see. If there was a cv headed car in there.
EHTTFMF!
Old 07-15-2013, 08:51 PM
Exclamation
what are you saying Mike????
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 07-15-2013, 09:00 PM
mike leech's Avatar
it will not go as fast at 3522lbs as it will at 3330lbs. seems simple.
However if i was to get someone to whine about putting weight in their car, and it was llijacks pa's car or had cv1s i might just add the weight. strait forward.
i Would prefer to race jacks dad in the q 16 tho....
EHTTFMF!
Old 07-16-2013, 09:26 AM
Yes he lifted, my pal at work does all the work on the car. He usually runs 162 mph.
The car was a real 86 Pro Stock ride, been updated to current specs. Light as hell. 555 with heads that only flow 380. Same heads on a 488 ran 8.20. We all told him to keep the heads on the small engine. Now he makes so much TQ it skates around a bit.
Could have had the car for 12K at one time.
Old 07-16-2013, 01:20 PM
john marcella john marcella is offline
Tom Vaught
Tom , Mike had a stock set of heads already, I welded the push rod holes and put them were they needed to be for the rocker offset that he has. Its only a .400 offset.
Did you really think you needed to tell me that info? If so you really have no clue about the things I do. And don't take that bad, its not meant that way.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 07-16-2013, 01:32 PM
GTOGEORGE's Avatar
Nice heads!
John, one of Toms 15,000 informative posts!
GTO George
Old 07-16-2013, 01:40 PM
mysticmissle's Avatar
Lol pretty sure that post was not for you John M! John or mike is there any pics Available of the work done on the manifold that feeds those heads. ?
Old 07-16-2013, 02:57 PM
mike leech's Avatar
ya i think johnta1 was who tom was talking to. LOL
EHTTFMF!
Old 07-16-2013, 03:18 PM
LOL
Well , sorry Tom. My bad. I guess its a good thing I wasn't a dick in that post.LOL
John Marcella
[email protected]
ph. 248-259-6696
Old 07-16-2013, 07:10 PM
Ron H's Avatar
Ron H Ron H is offline
LOL
Even when you are not being one you can still be taken as a Richard Head!
Make anymore passes this past weekend?
Mike, I bet that paint job is turning some heads.
Wish I could be at Norwalk. I think this years lineups should be one of the best ever.
68 Firebird
Are you running with the wind or breaking it?
  #38
Old 07-16-2013, 07:20 PM
Yes, the reply post was directed towards John Wallace.
The "Pile-On" post by George was expected and nothing new.
The post by me could have been worded differently listing John Wallace name vs just, "John".
So the "original sin" was on my part, not making it clear to John M which "John" I was addressing the reply to.
Mike Leech figured it out though. Mike Leech is a pretty sharp guy about reading stuff before he makes a reply.
Tom Vaught
  #39
Old 07-16-2013, 07:40 PM
GTOGEORGE's Avatar
Thank You, Tom!
GTO George
  #40
Old 07-16-2013, 08:39 PM
tom s tom s is offline
Jeff,tell Mike that the quickest car has not always won the money!I think its way easyer to get some cash out with 8 cars then 16.Tom
