Old 09-26-2013, 09:21 PM
geeteeohguy's Avatar
The whole thing is painted a semi gloss black. I used a cut off wheel perpendicular to the back and just ran it along the back area crosswise. No need to cut between the fins. It's thin aluminum and goes away really quickly.
Jeff
Old 09-27-2013, 06:03 AM
67gtospud's Avatar
67gtospud 67gtospud is offline
Thank you, I will have to give this a shot.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 09-27-2013, 05:22 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
I've done this to two scoop inserts myself. I think it's the best looking way to have functional scoops & also helps to keep debris out. If I was going to race the car, I believe I would pull the whole insert out & make a larger opening for the intake air. I've always felt that the small openings with the ribs still in might impede airflow a slight bit.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
