I came across a 67 convertible for sale local to me. It's pretty rough and does not have the original engine or auto trans.
Other than the Build Sheet or a PHS package is there any way to determine which V8 engine this car originally came with? I have the VIN and Trim Tag codes. Thanks, Dave
68 GTO 68 GTO Convertible 68 LeMans 68 LeMans Convertible 68 Tempest Convertible 79 Firebird |
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Derek,
That was one of the many sites I had checked but from what I can see the VIN will only distinguish between 6 and 8 cyl. engines. Dave
If "3f" is on the trim tag, then the car was a 400. Other than that and the code for i6, that's about it. If it is a v8 code and does not have the 3f, then it would be a 326. This only applies to '67 model year.
Well no 3F on the tag. The tag looks like this.
139 05B ST 67-22467 LOR 3139 BODY TR 254-2 R-1 PAINT W2W From what I can gather, Standard Parchment int. Buckets w/o headrest Reg. Red with Ivory top Not sure what the W2W designates. Does anyone know? Thanks, Dave
The W in the first group represents:
W = Tinted Glass Windshield The 2 W is for the PowerGlide transmission. The 2 denotes that it is Group 2. W = 2-Speed Automatic Tranny If you scroll down to the bottom of this page you will see all the codes listed by group: http://www.firebirdgallery.com/67codes.htm
1968 Firebird 400 coupe, Verdoro Green w/black vinyl top 1969 GTO Judge, Carousel Red, 4-speed, numbers matching 1971 Trans Am Cameo White, Auto, numbers matching 1970 Buick Skylark Custom convertible Fire Red 1972 Buick GS 455 Stage 1 Royal Blue |
Thanks for all the info it's a great help.
Now I just need to decide if I really need another project car. Dave
"...ridge reamer and ring compressor? Do they have tools like that?" |
The original engine and trans not the only thing they got rid of. Most of the interior is gone, all of front sheet-metal is off but he has another front clip for it.
The engine in there now is a 69 350 with 47 heads (not sure if it will even turn) but it does have a nice thermoquad and interesting aluminum pontiac logo valve covers. Dave
Funny! 69 350 with 47 heads is what currently resides in my 67.
>Sounds like someone already got rid of the 326/st300 for you, which I would say is a good thing.<
If I could add to it, the car needs a 400 or larger Pontiac replacment engine. Do it the right way. If it's not a numbers-match small-bore engine, the correct way to get the most resale value is 400 or larger engine. |
