Old 10-11-2013, 12:17 PM
jtwoods4 jtwoods4 is offline
Front Passenger side disc brake installed.
http://www.youtube.com/watch?v=xHMQE...ature=youtu.be
The Following User Says Thank You to jtwoods4 For This Useful Post:
Old 10-13-2013, 06:39 PM
FRONT END DONE!!!! SHE IS BACK ON THE GROUND!!!
VIDEO
http://www.youtube.com/watch?v=8dR6KkuX-lE
Old 12-09-2013, 02:23 PM
This weekend I pulled the original engine with 87,000 miles on it. Replacing with period correct 400 setup for road race performance and a tremec 5 speed.
You tube video
https://www.youtube.com/watch?v=zPbeqH-n9tk
The Following 2 Users Say Thank You to jtwoods4 For This Useful Post:
Old 12-25-2013, 10:48 PM
Recieved my restoried original gauges from Auto Instruments today. They rebuilt the speedo, converted the tach to work with a modern MSD, calibrated the gauges, rebuilt the speedometer, replaced the bulbs, glass, and refaced the numbers and colors on the gauge faces, and re-numbered the odometer. Very Nice.
One question... if you look at the third picture you will see the back of the small gauge cluster (voltage and fuel) and there is a small hole that the bulb goes in.
This bulb gets power from a small wire and rubber grommet that connects to the back of the bulb. However, the harness does not have anything that will securely hold the bulb in place, its just a rubber cup with a contact in it. How do I get the bulb to hold firmly in the back of the gauge cluster??????
Old 12-26-2013, 01:43 AM
transam1972 transam1972 is offline
Default bulb holder
you are missing a metal insert that goes in the hole, to secure the bulb
Old 12-26-2013, 01:45 AM
Do you know where I can get one of the metal inserts?
Old 12-26-2013, 06:49 AM
Default insert
I will take a look at mine and see exactly what it looks like as I just happen to be repairing my clock...perhaps someone with an old set of gauges with that part to spare
