Old 12-02-2013, 05:32 PM
Originally Posted by A Schab View Post
That chart has at least one mistake. The 69 manual trans with A/C uses the 5 blade power flex fan instead of the 7 blade clutch fan. I think that the same is true for 68 but I'm not positive.
At least two mistakes, but I bet there are more... 480033 5 blade flex fans weren't used until mid '70. The previous 5 blade flex fans were the "346"s.
The party putting the tech info together is using a later edition parts book where part numbers have been superseded. Can't repeat enough times, quality info on correct parts used comes from disassembling & documenting actual cars, not leafing through (often later dated) master parts books.
