#361
Old 12-20-2013, 11:17 PM
charlie66's Avatar
It peaked at 6600 and flat lined to 7500. We stopped at that point . So who knows how further it would of gone, at that point it didnt matter to me. It was a chassis dyno..
My Half AN Injun.....
  #362
Old 12-20-2013, 11:21 PM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by charlie66 View Post
All I know is when I shift into 3rd gear at 7300 it hits way harder then at 6600. So that's sayin something to me....
they don't want to get it.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #363
Old 12-20-2013, 11:25 PM
mike leech's Avatar
OK, lets talk acceleration rate.
I have a manual trans. (clutch) car traveling a long at constant velocity. I push the gas pedal to the floor and accelerate to the red line. Where was the max. acceleration rate as data logged on the G meter?
a) When I first floor the gas pedal
b) Peak Torque RPM
c) Peak HP RPM
d) Red Line RPM
e) none of the above
Stan
the engine accelerates faster just after peak hp
EHTTFMF!
  #364
Old 12-20-2013, 11:26 PM
charlie66's Avatar
I really don't know what I could say to further what I mean. All I know is its faster at the higher rpm.... I know this for a fact... I'm not saying know it all .Just what my car likes....
  #365
mike leech's Avatar
Originally Posted by 3fastgtos View Post
Here's my two cents.....crap, sorry it's only worth one cent. Carry on, Merry Christmas everyone
LOL!
EHTTFMF!
  #366
Old 12-20-2013, 11:30 PM
Stan Weiss's Avatar
what has engine acceleration has to do with car acceleration?
The car, by the laws of physics or if it is data logged on a race track will have max acceleration at about peak torque.
Stan
PS - Are you dyno racing?
Pontiac Pump Gas List
The Following 2 Users Say Thank You to Stan Weiss For This Useful Post:
  #367
Old 12-20-2013, 11:31 PM
cgeise's Avatar
cgeise cgeise is offline
Originally Posted by David Holmberg View Post
Absolutely, it happens to Langer from time to time.
I didn't include NA in the post because we were discussing a Turbo VS Nitrous car.
Nitrous is much more violent and therefor subject to upsetting the chassis, a turbo car by comparison is a smoother application of power-- in most cases. Get carried away with either and you get into trouble, but the same can be said about the upper end N/A car.
  #368
Old 12-20-2013, 11:35 PM
Stan Weiss's Avatar
Some of us get it, but clearly not Mike. He has mixed many different things together. Producing 800 HP @ 6000 RPM or 800 HP @ 9500 RPM has nothing to do with area under the shift curve. If your engine peaks at 6600 and flat lined to 7500 it is possible that you could shift higher than 7300 and still pick up et.
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post:
  #369
Old 12-20-2013, 11:39 PM
cgeise's Avatar
We all know that the more power pulses that happen in a given amount of time more work is being done -- therfore a better E.T.. An extreem example would be a 400 hp diesle where power is maxed at 2200rpm and a 400hp small block making max at 7000, given the same weight and set up properly the small block will win the race.
  #370
Old 12-20-2013, 11:43 PM
charlie66's Avatar
The way I see it is, If your making peak hp at 6600 and the same at 7300 the difference is , you are making the same power while generating more momentum and spending more time in that power range. To me it feels like the motor at that point is more violent.
  #371
Old 12-20-2013, 11:46 PM
slowbird's Avatar
slowbird slowbird is offline
Stan
Must fast drag cars never see peak tq, they doing it wrong?
  #372
Old 12-20-2013, 11:49 PM
Hey wheres Motor Daddy??? He should be in on this !!!
  #373
Old 12-21-2013, 12:06 AM
lemans411's Avatar
lemans411 lemans411 is offline
Originally Posted by LiL Jack View Post
CV1TTFMF
That one makes me laugh when people post that one!
maybe some day jack lol
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #374
Old 12-21-2013, 12:21 AM
mike leech's Avatar
Stan
I just double face palmed so hard it hurt.
Stan you are lost in the space between your ears. You've tried squirming all over the map on this to change the subject in failed attempts to make some incoherent ...thing. Now you claim its me changing the subject. Clearly your "geniusness" is blinding you from how it really works in the real world. I'm done with this. Sad part is you will carry on with your self appraised expert opinion and mislead some poor guy along the way into spending money in the wrong places. Why don't you help some na CV1 guy get in the other lane and get a look at the back bumper from a distance....of my old a$$ crappy eheaded firebird. Should be easy for such a smart guy and a superior canted valve head.
EHTTFMF!
  #375
Old 12-21-2013, 12:22 AM
Stan Weiss's Avatar
My example was a stick on a track. That does not have to mean 1/4 mile track which most here run. Also most here run automatics with torque converters. What happens when the engine side of the converter is turning faster than the transmission side of the converter?
These were done sometime ago for a different thread on a different form. One shows the HP and torque curve the other map rear wheel torque and RPM against MPH. Acceleration in G's in each gear will follow the rear wheel torque curves. the yellow line show peak wheel torque / max acceleration for that gear the red line shows where the wheel torque for that gear would equal the wheel torque in the next gear. A good starting point to try and shift at. Also for this example the trans gears ratio were make so there was a 90% drop between each.
Stan
ID:	347048   Click image for larger version
  #376
Old 12-21-2013, 12:28 AM
Stan Weiss's Avatar
Your problem comes down to reading comprehension or sadly you have a hard on against the CV-1's which you keep talking about which has no bearing on this thread.
Stan
  #377
Old 12-21-2013, 12:36 AM
Stan Weiss's Avatar
Originally Posted by Aaron Quinton View Post
Gaby,
I agree with you, area under the power curve over the operating range in the application is what makes the car move.
Why does the HIGHEST rpm possible make it any faster?
Mike,
Why do you or Gaby not answer Aaron's question.
Stan
  #378
Old 12-21-2013, 12:44 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
no gas peddle on a computer or calculator though.
that is true!!!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #379
Old 12-21-2013, 04:16 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Jeff Kinsler View Post
... FOOT ON GAS PEDDLE...
"Peddle" isn't even a noun. It's a verb, meaning "to travel about selling wares".
The Following 4 Users Say Thank You to Jack Gifford For This Useful Post:
  #380
Old 12-21-2013, 04:25 AM
... (what's that head called anyway?)...
Visner calls it a "Billet Force Cylinder Head, Pontiac Symmetrical Canted". They also have a Pontiac non-symmetrical- appears to be non-canted, but can't tell for sure from the pictures.
The Following User Says Thank You to Jack Gifford For This Useful Post:
