I'll make this short. When I did a rear disc conversion using S10 parts, I found it necessary to fab some spacers. Then last week I found these on eBay, from seller ID S10 Warehouse. Nicely laser cut spacers, and only $29.99 a pair. Got them already, just have to wait for a bit warmer weather to try them on.
"GTO......Gas, Tires and Overdraft"! ![]() '70 GTO convertible, 434, 4-speed |
Thanks for the info. I will be doing my conversion in June of 2014.
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
Interesting to see this thread.Makes me wonder about these spacers as I've obtained a rear caliper setup from a 2001 blazer I plan to use on my project65.Seems I remember another member who had used the same setup as i and mentioned some slack after installing the setup and had to make some sort of shims.Maybe these would be something I could use as well.Is the S10 setup much like the Blazer setup i'll be using?
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
S10 pick up, S10 Blazer, GMC Sonoma, S15 Jimmy, T15, all the same. I think that other member you remember was me...a couple of years back. These spacers are a more elegant solution to the problem; if you have any questions I'd be glad to help. I made extensive notes about the conversion, which you may find useful.
"Time flies. The spacers are 1/4" thick. I'll know how they fit when it gets warmer here! I did my e-brake cables like this. First, find a pair of S10 Blazer or pickup parking brake cables in the junkyard, cut the frame ends off, pull the braided cables out; you don't need the housings. The brake ends have the necessary closed hook style terminations, and I got the cable tension springs as well. Get a pair of replacement GTO cables (Advance Auto Parts had the best price for the cables, at $18.99 each). Cut one end of the cables off, then simply put the S10 cable into the GTO housing. The S10 cable is sealed in clear plastic, and slides in very smoothly. Last, find someone to swage new frame ends on the new cable, only after you get confident that the length is OK. Oh, and the junkyard cables were $1.34. It all comes out looking like it came that way. Hope this helps"
Good info on the ebrakes.I obtained the e-cables from the blazer I got the rear setup from.I've also got some good quality ecables/housings that came from a 66 that I may cleanup a little and use.That would need me having the frame ends done.Today I was speaking with a mechanic friend and explaning to him how I need to do the setup and mentioned the redo of the frame ends and he told me ,he understood theres supposed to be a tool available at LOWES that will do just that.That has me curious and may see if I can locate such a tool.Looks as you may get around to exchanging your spacers before I do my brakes and if or whenever you do.could you do some pics to kinda show just how these new pieces install etc. Thanks,DeWayne
Howie
I mean to ask you if told me your original spacers were made from taking some sort of spacer and cutting it so it would just slip over the axle.But is it mounted behind the backing plate? These ebay pcs look as though that's the only way they would work is if mounted against the diff flanges before mounting other hardware,so that's going to good to learn. Later,DeWayne
Appreciate the pics.So the spacer pcs you made appear to actually recess into the backing plate.
Yes, not ideal, but they worked. I was out in the garage last night with the intention of doing one side. Got everything ready and......my floor jack quit, sooo, I spent the evening repairing the jack. Will finish that job off this morning, and will hopefully have a spacer update today.
Well, fixing the jack didn't go well, in fact I left it apart and gave it away on CL free stuff. Bit the bullet and paid $80 (half-price) for a 3 ton at Harbor Freight, put the heater on and got one side torn apart. The spacer goes between the axle flange and the backing plate assembly to take up the .250" difference when going from drum to disc (on an S10, but I assume the A-body is identical since I had the same problem in the first place). Ran out of time to get it put back together today, so tomorrow is the plan.
Well, I should have known better when I couldn't figure out how the spacers would make a difference....they don't. Actually they do make a difference, in that they make the already large (.250") axle end play into .500". I'm sticking with my originals that I made which ride against the bearing, have good caliper alignment, and are already made. There has to be a difference between the S10 rear end and the BOP 10-bolt rear end; I just don't know what that is. Anyone wanna buy a pair of very lightly used S10 axle spacers......anyone?
I am working on a new design that uses the drum-in-hat setup; should have test pieces back from the cutters in about 2 weeks. This will dispense with the spacer nonsense and allow the use of bolt in axles.
Stay tuned... |
Now you tell me...LOL! Look forward to seeing the parts.
