Old 01-05-2014, 08:46 PM
Aus Goat Aus Goat is offline
Default 1991 FB engines
Hi Guys
We Have a air cleaner issue on a new motor we have no clearance so can you post your different air cleaner set ups so we can get an idea on what we can do or what it will look like . Currently running a low aircleaner with twin outlets wrapped around the motor looking for room and cold air .
Craig
Old 01-07-2014, 04:06 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Originally Posted by Aus Goat View Post
Hi Guys
Craig
Do you have a carb?
I almost bought a late 80s Firebird convertible with a carbed 305, supposedly it was a police or HD package, anyways, the air cleaner looked like regular black carb air cleaner with a single heat riser
it looked like this
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 01-18-2014, 04:02 AM
QF 750 VAC 2 on a EB manifold ( air gap ) but the vac port at the back needed to get clearance so owe installed a 1/2 ' spacer . And then the issues start
Old 01-21-2014, 12:05 PM
is there another vacuum port to use?
maybe you can plug that back vac port and install a T-fitting in another vac port so you can then manifold it out?
