#481
... how many times have you stated the heads suck, they don't make power' they can't make 1000hp, etc etc ?? ... ... but after years of your bashing and slamming, when i ask if you've considered Fulton may well hand you your azz, you don't deny, in fact you make an excuse based on pound for pound ?? This aint boxing Jack ... ... if the head is such a POS, then how is this even possible ?? i mean with your new super donkey-phuck billet top end and all ?? ... ... are you that quick to admit Fulton might just whip that azz ?? ... i mean one minute your skull phuking the donkey with Fulton, and now you're already making excuses about pound for pound stuff ?? ... ... please make up your mind already, either you hate them, or you don't ... and for the record, what will the red sled weigh this year Jack ?? because i think you and Fulton will be closer in weight than you'd like to admit ...
#482
I think this would be the issue regarding weight.
Your HP is 1,457.71 computed from your vehicle weight of 3500 pounds and ET of 7.8 seconds. Your HP is 1,166.17 computed from your vehicle weight of 2800 pounds and ET of 7.8 seconds.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#483
he did however run a 7.98 @ 171 at 3100 lbs in the video below. pay no attention to the lemans in the near lane that got nervous and red lit. on a side note its kinda funny that both of the cars in this video are currently changing over to A.P.D. ported CV1's . http://www.youtube.com/watch?v=PQtA6SKGojk
-Rob 67 LE MANS in pieces... 68 gto 84 grand prix twin turbo 496 pontiac 25.3 cage |
#484
#485
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
| The Following 2 Users Say Thank You to mike leech For This Useful Post: | ||
#486
N2o and lots of it
| The Following 2 Users Say Thank You to john marcella For This Useful Post: | ||
#487
Still need to master the concept of letting your actions and results speak for your words. The names have changed on the cv side but the idea of We Will doesn't have the same cache as We DID. Until you do its just lip and snake oil.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
| The Following 4 Users Say Thank You to mysticmissle For This Useful Post: | ||
#488
Based on what you do for a living, the companies you work for, the size of that engine and the head layout on that engine it better make 1,000+ on the DYNO and show it at the track.
#489
didnt you read the thread that the ECM hurt his business and he cant make anymore heads? He is sold out of heads and I thought thats a good thing!!
EHTTFMF
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
#491
A 572 c.i. max effort should make 1150 min for a head that flows as much as ttbill says it does.
#492
DIDTHATJUSTHAPPEN
#493
So selling 100 pairs of heads over what 5 years, which is an average of 20 pair per year means that his business was doing good? ![]() Stan
| The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#494
Lil Jack,
Since you are so good at predicting how much HP Bill's motor should make or he should melt it down!! How much HP is your POS going to make or you will should melt it down!!!!! Stan
#495
E-heads, HP and Tigers heads have made around 2.4hp/cfm the cv1 should be able to match that, right? So 480cfm is 1150hp, 500cfm is 1200hp, what do Bill's heads flow? Also 1150 to 1200hp is between 2 to 2.09 hp/ci which should be more than doable. So Kinlser's min hp of 1150hp seems reasonable
| The Following User Says Thank You to slowbird For This Useful Post: | ||
#496
there has not been a single 4 tiger headed motor that made over 1160 to my knowledge.
#497
as the stroke goes up the hp per cube will go down....not always the case. |
#498
Can you tell me who has made 2.4 HP / ci with a Pontiac engine? I know of only two who are in that area. Pickett and John Marcella Stan @ 2.4 HP / CI ___CI_________HP 400.0000______960 410.0000______984 420.0000_____1008 430.0000_____1032 440.0000_____1056 450.0000_____1080 460.0000_____1104 470.0000_____1128 480.0000_____1152 490.0000_____1176 500.0000_____1200 510.0000_____1224 520.0000_____1248 530.0000_____1272 540.0000_____1296 550.0000_____1320 560.0000_____1344 570.0000_____1368 580.0000_____1392 590.0000_____1416
#499
You think 2hp/ci is asking to much from a canted valve head, sheet metal intake and two 4's with a 4.750 stroke?
#500
