#601
Old 02-13-2014, 10:21 AM
wreckmastr's Avatar
Which intake did you decide on??
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
The Following User Says Thank You to wreckmastr For This Useful Post:
  #602
Old 02-13-2014, 11:24 AM
Originally Posted by LiL Jack View Post
Nice plastic spacer, did someone not calculate the runner length properly?
And that was 3-1/2 YEARS ago!
Manifold is std deck... block is an IA tall deck... thus the spacers... This pic is from early on in the prototype stage...
  #603
Old 02-13-2014, 11:27 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Originally Posted by Jeff Kinsler View Post
LMAO..
Nevermind! I can't say it
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #604
Stan Weiss's Avatar
Lil jack,
If you ever built any engines you would know when you put an intake designed for a standard deck height onto a raised deck height engine it needs spacers.
Stan
Pontiac Pump Gas List
  #605
Old 02-13-2014, 11:29 AM
Hint... read the valve covers.
fwiw pics of the bigger intake just dont capture the reality of the runner size. (or the ports it feeds)...
  #606
Old 02-13-2014, 11:35 AM
wreckmastr's Avatar
Hint ..... He posted both in HIS 572 thread that's why I asked.
http://forums.maxperformanceinc.com/...d.php?t=731179
6.98 @ 199mph
4.53 @ 164mph
  #607
Old 02-13-2014, 12:57 PM
cgeise's Avatar
cgeise cgeise is offline
Originally Posted by john marcella View Post
Cant what? You have asked me a direct question about nothing.
1000 / who cares? old hat
1100 / not a big deal, been done a few times
1200 / been done once, and is the new target for many.
So again , cant what? How high is the bar set for your personal hurdle ?
While those are benchmark numbers I think its more important to look at HP per cid to see a heads potential -- 1100 out of 500 ci is way more impressive than 1200 out of 600 plus ci if you do the math. So -- if a cv head makes 1000 on a 572 is it as good as a e-head on say a 540 that makes 1000 ??? close but no,
  #608
Old 02-13-2014, 01:51 PM
Hint ..... He posted both in HIS 572 thread that's why I asked....
Not me. just sayin; I gots a 472
  #609
Old 02-13-2014, 02:51 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Thumbs up laughable.....
lol.....and so says someone that has never made any power N/A with a pontiac....you are starting to sound like Stan.
  #610
Old 02-13-2014, 03:17 PM
john marcella john marcella is offline
Well then you should stop looking at Pontiacs.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #611
Old 02-13-2014, 03:35 PM
Stan Weiss's Avatar
J.C.
Different people run different classes which have very different rules. If you run a class with minimum weight and not max. ci you you build to produce the max. HP however you can. Other people run a class which is based on pounds per ci. The above engine would have its a** handed to it in these classes. Different strokes for different .....
Stan
  #612
Old 02-13-2014, 03:54 PM
cgeise's Avatar
HMMM lets see over a 1000hp with a 540 In a BRACKET CONFIGURED ENGINE - it runs in Super Gas -- and has to go round after round -so lets see - your 1.97 hp per ci to my 1.87 hp per ci --- your 30,000 dollars in a top end to my mmm maybe 10k --- take away your extra 60 cid and your upper 1070 to 80 or so - not bad -- but not the end all --- now compare dollars to hp - and well you get it - Unless you need me to simplify it some more.
  #613
Old 02-13-2014, 04:29 PM
J.C.you's Avatar
Talking
J.C.
Stan
ok, Stan, u the calc king. Keep on calculating.
  #614
Old 02-13-2014, 04:36 PM
GTOGEORGE's Avatar
Curt,
It's the round after round after round thing
that's confusing some racers. They Just don't understand, it's a new concept to them! LOL!
GTO George
  #615
Old 02-13-2014, 04:44 PM
J.C.you's Avatar
Any dyno sheet of your claimed 1000hp motor? Weight and all out ets, in what type aero body? I smell some BS.
  #616
Old 02-13-2014, 04:52 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
That's not BS.
[email protected]. 3460#s
The Following 2 Users Say Thank You to LiL Jack For This Useful Post:
  #617
Old 02-13-2014, 05:51 PM
David Holmberg's Avatar
That's not BS.
Agreed, Curt has the real deal.
The Following 2 Users Say Thank You to David Holmberg For This Useful Post:
  #618
Old 02-13-2014, 06:02 PM
wreckmastr's Avatar
As requested Mr.Geise's dyno sheet's
6.98 @ 199mph
4.53 @ 164mph
  #619
Old 02-13-2014, 06:08 PM
LiL Jack's Avatar
Nice 1009 HP @ 7,000 RPM!
Probably easy on valve train with that low rpm.
  #620
Old 02-13-2014, 06:21 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Is this a Pontiac engine? Build details?
The Following 2 Users Say Thank You to v869tr6 For This Useful Post:
