I always like to look a manual trans / clutch cars because the torque convertor adds an extra degree of complexity. While the max acceleration in any gear is at max torque that is only really important for a drag racer in first gear (road racing is a different story). Once you get passed max acceleration in first gear the question is how many RPM to turn first gear until shifting. The starting point (track test is the final answer) is when wheel torque / HP in that gear drops below the wheel torque / HP at the RPM you drop to in the next gear. These are fixed percentages / RPM with a manual trans / clutch. With an automatic the torque convertor /stall speed acts as a modifier to that RPM. Which is why the added complexity from a torque convertor. ![]() Stan
1989 Automotive Hall of Fame Inductee |
