| The Body Shop TECH General questions that don't fit in any other forum |
Anyone have a picture or a bare frame they can take one I need a close up of the frame right behind the pass tire there is a slot in the frame I think that is where my issue is it does not look right .
It does not have the same issue on the dr side so pissed right now I can't see straight. |
I have a bare frame, but it is for a convert., so I think it will be different. (let me know if you want pics of that)
Have you measured using the 'X' method? pick a spot on the rear pass side of the frame, and measure to a spot on the front driver's side. Then measure from the same points on the other sides, and see if there is a difference. If there is a difference, then your frame is not 'square'. |
Working on the new frame I had delivered round 1 course wire brush on the Makita 2nd round 80 grit flap disc de bur all the welds and removed all extra slag 3rd round HF pressure blaster with medium grit media. Epoxy primer and ceramic paint this weekend. Forgot how much work went into the first one.. Talk about setbacks rather not.
