i am parting out my 68 firebird here is a list of what i have please do not pm me as i do not get on this site a lot email me at [email protected] or call/text me at 810 962 4569 thank you list is current as of 4/25
Subframe NICE 400 Doors 200 each 3 available Drive shaft 50 each 3 available Heater control cables 20 Power steering gear box 100 Original inner fenders 100 each driver side available front valance 50 Drip rails 50 per pair Window regualator 50 a pair Door gasket 20 a pair Tilt steering column 400 Front coils new 40 Center console 200 Cowl cover 25 2 availabel Th350 crossmember 50 Th350 crossmember modified to fit th400 80 Th400 crossmember 200 Rear glass 50 each 2 available NIB tubular control arms upper and lower 250 Hood hinges 80 ¼ window tracks 50 a set Complete wiring harness 50 Nova 8.5 non posi rear end 250 NOS pitman arm 30 Washer jug bracket 10 Rear bumper brackets 200 Headlight plated 45 each 2 available Fender guessets 60 pair Fender extensions originals 40 each both sides available Taillights 60 dollars 400 hood scoops inserts originals 100 per pair Shifter with nob and plate 150 Shifter 100 Parking brake pedal 25 Brake pedal 50 Gauges rally 67 120 mph speedo with housing 250 Gauges rally 160 speedo with hosuing 250 Heater controls 125 Dash bezel around radio ash tray 30 2 available Glove box door 20 A pillars 25/pair Visors 25/pr Arm rest 25/pr Rear view mirror 24/pr Headlight switch 15 2 available Steering column braces 25 Lighter 10 Washer/wiper switch 15 Speaker bracket 15 Inner fender brackets 30/pr Wiper arms 30 Horns 20 each 4 available Fuel door 40 Washer jug 10 Fuel neck 20 Fuel neck cover 15 Gas pedal with cable 25 Wiper motor with trans and rebuild kit 100 Floor pan under rear seat 30 each both sides available Grill inserts 20 each 3 available Rubber that goes in front bumber ends 100 per pair Seats 350 a set Heater vents 100 Front turn signal leses 60 Headlights and buclets 60 for 4 Hood latch 125 Leaf springs 100 Motor mounts 50 Repop rubber motor mounts 30/pr Turn signal metal housing 100/pr Wire cover under sill plate 80 a set Gas tank straps 20 Rear arm rest 150/pr 2 available Sail panels 40/pr Duct work 30 each 2 available Ash tray 40 2 available Heater core box NICE 100 Seat belts 30 each 12 available Horn button 100 Column cover 25 Front window trim 125 Rear window trim 125 Ac filler panel only one side so far 40 Decklid 100 |
I sent you a pm about the 67 rally gauges.
updated list please do not pm email call or text
67 68 firebird parts i am parting out my 68 firebird here is a list of what i have please do not pm me as i do not get on this site a lot email me at [email protected] or call/text me at 810 962 4569 thank you list is current as of 4/25 Subframe NICE 400 Doors 200 each 3 available Drive shaft 50 each 2 available Heater control cables 20 Power steering gear box 100 Original inner fenders 100 each driver side available front valance 50 Window regualator 50 a pair Door gasket 20 a pair Front coils new 40 Center console 200 Cowl cover 25 Th350 crossmember modified to fit th400 80 Th400 crossmember 200 Rear glass 50 each 2 available ¼ window tracks 50 a set Washer jug bracket 10 Headlight plated 45 each 2 available Fender guessets 60 pair Fender extensions originals 40 each both sides available Taillights 60 dollars Shifter with nob and plate 150 Shifter 100 Parking brake pedal 25 Gauges rally 160 speedo with hosuing 250 Heater controls 125 Dash bezel around radio ash tray 30 2 available A pillars 25/pair Rear view mirror 24/pr Headlight switch 15 2 available Steering column braces 25 Lighter 10 Washer/wiper switch 15 Speaker bracket 15 Inner fender brackets 30/pr Wiper arms 30 Washer jug 10 Fuel neck 20 Fuel neck cover 15 Floor pan under rear seat 30 each both sides available Rubber that goes in front bumber ends 100 per pair Seats 350 a set Heater vents 100 Front turn signal leses 60 Headlights and buclets 60 for 4 Leaf springs 100 Turn signal metal housing 100/pr Wire cover under sill plate 80 a set Gas tank straps 20 Rear arm rest 150/pr 2 available Sail panels 40/pr Duct work 30 each 2 available Ash tray 40 2 available Heater core box NICE 100 Seat belts 30 each 12 available Horn button 100 Column cover 25 Front window trim 125 Rear window trim 125 |
Received the box and gauges. Looks great, packed well. Better than described. Thanks and bump up
The 67 rally gauges and th350 crossmember both arrived last Fri. The gauges look very nice. Better that the pic's showed.
Thanks, Rob |
Any pics of hood latch??
do you have the 67 firebird door glass track assembly ?
Console still available?
I'm interested in your th. 400 cross member and your drive shaft if it's for a th. 400. Thanks, Kenny H
Hi. Do you have the interior rear view mirror?
He has not been on the site since 2019
