Old 06-15-2014, 11:40 AM
jims68ragtop's Avatar
jims68ragtop jims68ragtop is offline
Default DRIVER'S SIDE HORN
The driver's side horn is not working on my '68 Lemans. The passenger side still works. Since the passenger side is fed from the driver's side, I am assuming that the horn itself is bad. I also tested this by removing the horn and using jumper cables to try to get it to sound. I was not really sure if I was doing it correctly.
Anyway, I was wondering if anybody knows if the driver's side horn is the low tone or the high tone. Since I can only hear one sound, I can't tell which it is.
Thanks.
Old 06-16-2014, 08:54 AM
2002Z4CSS's Avatar
On some horns it has the note cast into the horn. I am not sure about a 1968 horn. Later GM horns show the note.
1971 Pontiac GT-37
Old 06-16-2014, 04:45 PM
Thanks for the info. The broken horn has a "C" stamped on the side that says Delco Remy and "N2" on the other side. Maybe it is safe to assume it is a C note, but then is that the low or the high?
Old 06-17-2014, 03:56 PM
Andre's Avatar
Andre Andre is offline
Not 100% sure, but I think the smaller horn is low note and the bigger one is high note.
Old 06-17-2014, 04:31 PM
Old 06-17-2014, 11:18 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
I can check tomorrow. But, one would assume that the larger horn would have a lower pitch due to size/length of resonance chamber...
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 06-17-2014, 11:37 PM
berrygoat's Avatar
berrygoat berrygoat is offline
http://www.classiccarhorns.com/index.html
Great work, fast turnaround.
Old 06-18-2014, 03:35 PM
Thanks for your responses.
