| The Body Shop TECH General questions that don't fit in any other forum |
#81
Anyone have a picture or a bare frame they can take one I need a close up of the frame right behind the pass tire there is a slot in the frame I think that is where my issue is it does not look right .
It does not have the same issue on the dr side so pissed right now I can't see straight. |
#82
I have a bare frame, but it is for a convert., so I think it will be different. (let me know if you want pics of that)
Have you measured using the 'X' method? pick a spot on the rear pass side of the frame, and measure to a spot on the front driver's side. Then measure from the same points on the other sides, and see if there is a difference. If there is a difference, then your frame is not 'square'. |
#83
Working on the new frame I had delivered round 1 course wire brush on the Makita 2nd round 80 grit flap disc de bur all the welds and removed all extra slag 3rd round HF pressure blaster with medium grit media. Epoxy primer and ceramic paint this weekend. Forgot how much work went into the first one.. Talk about setbacks rather not.
#85
What happened with the frame shop guy that said the cradle was the problem? Did you have him try and fix it? Just curious what the final determination was regarding alignment problems with your original frame.
#86
I bought a 66 Lemans parts car and stripped it down to measure the frame the frt horns were exactly the same as mine I also measured the roll in the horns and it was the same on both frame .I took the frt clip off mine to measure the frame and borrowed a digital caliper from a friend the dr side was the same the pass side had a set back of 1.75 inches from the upper ball joint to my indictor marks the lower ball joints were the same so being that the eng would have to come out to make the pull and the frame heated and stretched the cost factor was about the same to replace the frame and there were no guarantees the pull would hold so here I am reconditioning another frame what a setback but almost done hope to have the epoxy primer on it today paint Wed then start the swap should take about a week .
#87
After many hours stripping under coat smoothing welds wire wheel glass beading it's done ready to start swapping anyone want to help! anyone free beer food pool extra rooms lol..Fla vacation..
2qt's House of Kolor black epoxy primer nice stuff to work with went on like silk. 2QT's Eastwood ceramic sating extreme chassis black 2 cans Eastwood internal frame coating stuff is great very impressed |
#88
That is a piece or Art!!
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege" www.musclecargalore.com [www.reverbnation.com/nikivee 1967 Pontiac GTO 1967 Pontiac Grand Prix 1972 Pontiac Lemans Sport Convertible 2015 Dodge Challenger Scat Pack 392, 6 speed 2021 Ford Explorer |
#89
Thanks was allot of work and it's smoking hot here now I have to figure out how to flip it.
#90
Forgive the simple comment here, but many have made the mistake of checking steering clearance with the front end jacked up and front suspension hanging. I didn't see in your postings how you were checking clearance, but it can only be checked with weight on the front end.
Tires hit the frame badly when the car is jacked up in front--a condition you would not encounter in actual driving.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
#91
Making good progress on the new frame swap really hot out very disappointed in the quality of the muffler hangers already separating .
#93
Really looking nice! Your about ready to drop a body on it!!
#94
Thanks Steve just got chased out of the garage lightning struck so close made the air on my arms stand up .Sent pcs of the hangars and they are sending me a new set. Pulled the motor and frt end today cleaning and tweakin some things wanted to do a little differently now just need to figure out how to transfer the body hard to do by myself.
#95
That's not a one man job! Unless you have a 2 post lift.
#96
Had to do it by myself last go round slow and easy got it done.
#97
I used 2 old engine stands to make a frame "rotisserie". I just welded round stock to some rectangular pipe and used a torch to make big holes in the end to run a big bolt with a big washer and bolt it to the frame.
#98
#99
That's what I did last time but now I have glass in the car just have to figure out how to distribute the weight and have nothing under the car so I can roll the new frame in.
#100
Yikes!
