Old 07-21-2014, 12:02 AM
70RAlll 70RAlll is offline
Has anyone figured out what that small stamping on the port opening flat is??I have seen more without it, but without a doubt have seen some with it.. seems it is hit or miss if yours got that stamping.. none of 3 I have here have it.. the ones I have seen ,from memory, started with a "cs" or something similar?? like a 2 letter then a string of numbers stamping ??
Old 07-21-2014, 07:13 AM
Pepi's Avatar
Pepi Pepi is offline
I thought the csxxxx was the date code. I know I had a thread somewhere asking the correct one for my 73, and that was it. Because I was hoping to find one. I have to look later for that thread.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 07-22-2014, 12:47 AM
TA455HO's Avatar
TA455HO TA455HO is online now
I'll get the master cylinder painted semi gloss black before I install it on the car. Thanks everyone for the input on that.
Chapter 3 Verse 1 - Front Suspension
Lol
1362014 6.176 All F BUMPER (upper arm) 2 1970 1975 6-4
One of those favorite pieces to install.
3973052 6.176 All F BUMPER (lower arm) 2 1970 1973 6-4
Not sure if you can make out the number on the pick tag or not, but it is there.
5535623 7.345 All F .................... SHOCK PKG. (front) 2 1970 1971 7-9
Stamped with number 3192132 - These are the 1980's service replacements.
Delco marking in rubber grommets 381957 7.244 Fir. exc. 400 4 B.C ....... GROMMET, frt. stab. link 8 1970 1971 7-7
396797 7.245 All ...................... RETAINER (front) 8 1964 1970 7-8
1365067 7.347 All ...................... NUT, frt. shock to upper brkt. (~xs''-24) AR 1964 1970 7-13
482332 7.242 All F/Trans. Am BRACKET, front stabilizer shaft (w/firm 2 1970 1971 7-7
9432415 7.242 All F/400 Trans. Am.-- (8.907) . SCREW, frt. brkt. to frame (%''-- 16 x 1'' so 4 1970 1972 7-7
482331 7.243 All F/Trans. Am. or Formula BUSHING (front) (w/15'' whl.) (11/4'' I.D.) 2 1970 1971 7-8
464167 7.240 F W/WS4, W66 ............ LINK KIT, FRT STAB 2 1978 1981 7-3
These are the later 70's style. I think I still have what could be originals. I'll have to dig them up for comparison to what you guys have.
Might be a couple of days before my next update here. Keep the comments coming.
