If you have an 8.50 chassis tag, a set of 370+ HP's, .750 lift cam and a 535 can get you close at about #3000. Easy on springs too. I ran 8.69 @ 159 with very little tuning, chassis or motor. I told SD Dave that I wanted to run 8.80's all day long in the heat and not change springs every year. It runs mid 8.70's to low 8.80's most anywhere. Here's my cam card, to give you an idea.
Runner Up Q16 Norwalk 2013! |
Think I'd be looking for someone familiar with the "real estate" though not mandatory if you have the right guy. IMO Its more important that whomever I chose is able to meet the requirements of my build goal. Generic port that covers a broader range of application or port that best meets the specific build requirement? |
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Especially when some don't even have a HP head and 'giving' advice.
2 people in this thread have/run HP heads.
To the op, just do your research, set your goals, see who is running what you want to run or making the hp you want then find out who did their heads. Last edited by slowbird; 12-24-2014 at 12:48 PM. |
Hill Performance has done some real nice flowing KRE HP, trend is @ PY.
I have that engine in my car...mine is the original one they advertised @ 1030hp with just the cast Wenzler quad intake. Jeff told me it would go 1075hp with a sheetmetal intake. The motor makes steam. Just everything else in my car needs tweaking. Converter, suspension, ........
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot 72 LeMans "POS" - Next US beast
Stated- "Think I'd be looking for someone familiar with the "real estate" though not mandatory if you have the right guy."
Agreed, not always mandatory. Nine years ago I bought a very early set of High Port castings and we had a fellow named Rick McConathy do the port work. Rick was well known for his Chevy cylinder heads and was associated with Naiser Racing Components in Houston, Texas at the time. I believe now his business is Slick Rick Racing Heads. These guys were well known and very competitive in Texas Pro Stock Racing circles. On the first go around the heads were 403 cfm at 0.800" lift, later with additional work 412 at 0.850" on Jeff Naisers flow bench. On my engine builders bench they went 417 cfm at 0.850" lift. Later with these cylinder heads our 930 hp 526 cid Pontiac engine was pretty good stuff, today it's no big deal. Same with the heads. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-24-2014 at 01:58 PM. |
FWIW Dan Barton is at Naiser now doing their heads now.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
http://www.hotrod.com/how-to/engine/...-engine-build/
Carburetor building & modification services Servicing the Pontiac community over 25 years |
I guess dynos don't count?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Come on man. Where are you at NA? Or on the juice? Your engine has been on the pump. Where are you at in the "truth" position? KRE offers off the shelf a 1075 hp NA engine with cast High Ports and a cast manifold. You and Gaby must have delivered more with the billet head, DRCE, bad arse, best of the best, canted valve racing engine. Since you know, you must have delivered significantly more power. Where's it at man? Dyno sheet please.
you not having a mr1 never stopped you from shameless plugs and giving advise.....just sayin.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
![]() ![]() ![]() Think you know everything I guess? FYI, there's a MR-1 block and a HP heads in my dragster out in the garage.
#38
Best porter for what application? There are to many variables in this. If you wanted every last bit they could possibly give you the bill will be huge. Not to mention the valvetrain expense (like previously mentioned) it would require to make power with them. Everyone has a budget (some larger than others) that they have to stay within. Its not that hard to figure out how much airflow you need to make X horsepower at X cubic inches. You may not need as much flow as you think.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#39
