Old 01-21-2015, 10:37 PM
mjm421's Avatar
mjm421 mjm421 is offline
Handled
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 01-21-2015, 10:49 PM
mike leech's Avatar
mike leech mike leech is offline
Done
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 01-22-2015, 12:19 PM
gkinch's Avatar
gkinch gkinch is offline
done!
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
Old 01-22-2015, 01:11 PM
JD311's Avatar
JD311 JD311 is offline
done
Old 01-22-2015, 02:09 PM
Its WAY Overkill. Once I was at a old junkyard and needed a windshield frame for a 65 Corvette. The guy looped the seal belts together and lifted the whole car with a forklift out of the line of cars it was in across a field to an open spot. Those belts were 35 years old, sun beaten and still held up the body and frame.
Old 01-22-2015, 02:19 PM
JD311's Avatar
Yeah, they pull engines out all the time with old belts at the JY lol.
Old 01-22-2015, 02:50 PM
estep455's Avatar
estep455 estep455 is offline
wont happen!!!!! especially not this year! that's a guarantee!
Old 01-22-2015, 03:06 PM
Region Warrior's Avatar
Who knows, could happen.
Old 01-22-2015, 03:21 PM
estep455's Avatar
Would be nice. But was already discussed and was considered but made clear won't happen this year. Sucks but that's what was said
Old 01-22-2015, 04:52 PM
Gman 6900's Avatar
Gman 6900 Gman 6900 is offline
Done
68 Lemans 505 cu in
[email protected]
69 FB 455 cu in
11.97
Old 01-22-2015, 07:29 PM
66bonne's Avatar
66bonne 66bonne is offline
Did it.
Jim
Old 01-22-2015, 10:13 PM
1FAST GTO's Avatar
1FAST GTO 1FAST GTO is offline
Thumbs up
Thumbs up!
Old 01-23-2015, 12:03 AM
azbirds's Avatar
azbirds azbirds is offline
Done!
Old 01-24-2015, 01:06 AM
NBF823's Avatar
NBF823 NBF823 is offline
I believe that an OEM is quite different than a racing harness. I agree that the two-year recert is quite short, particularly for a race car as most don't see to much sun shine.
On the street, it's a little different. I think my harnesses last about 4-5 years before they start to fray. A factory belt, which is more like nylon, seems to be impervious to UV exposure. My RJS harness is like cloth type feeling.
Hope I didn't tell you something you already know.
Passing on signing - not really involved in racing enough. Sorry.
Also I should mention that I strapped in my RJS harness probably some 2400 times in a street car over 4-years. That's not gonna help with fraying.
Jon B
Old 01-24-2015, 10:40 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Clearly, the rules should always allow a tech to fail any belt--regardless of age--with visible signs of wear.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 02-16-2015, 06:24 PM
gonuts gonuts is offline
Done
Old 02-20-2015, 02:25 PM
jal's Avatar
jal jal is offline
Done!
