Old 03-02-2015, 11:41 PM
dreamn69 dreamn69 is offline
Default Correct Alternator part number
I have tried searching, can't seem to find it. Can anyone tell me the correct part number for a 79 W72 Alternator?
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 03-05-2015, 11:00 AM
2manyT/A'S's Avatar
There was at least 2 .......with different outputs......
I have a chart here some where....will post if I can find it.....
#'s s/b same as 78....
Eye Candy......garage band?
Go full screen & turn it UP!
Old 03-05-2015, 12:15 PM
roundportponchos's Avatar
Default 78 date
I have a nos one,, can post pick. Later
Old 03-05-2015, 05:14 PM
that would help, thanks
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 03-05-2015, 06:31 PM
Bentwheelbob's Avatar
Here's a picture of my alternator. 1978 w72.
Old 03-05-2015, 10:05 PM
Default 78 alt
Here is nos I have, , its, a 63 amp, ac, as rear defog, or w72,
1102485, the one on stick, non ac, a 42 amp,
1102486, another used 61 amp, ac or rear defrost
I guess, any of these 3 #s were used, depending on options
ID:	391984   Click image for larger version
ID:	391989   Click image for larger version
Old 03-05-2015, 11:13 PM
Mine is 1102908 63A
78KO512
Could that be correct?
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 03-06-2015, 12:46 PM
Default 78 alt
I would say, wrong, those 3 numbers, I listed, are it, according to books I've read.
You may have a 78, could be another gm model
Old 03-06-2015, 05:24 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Originally Posted by dreamn69 View Post
Mine is 1102908 63A
78KO512
78K05 is the date code Oct. 5th, 1978. 1102908 is a Corvette alternator.
Old 02-23-2023, 11:35 PM
Maxthe222 Maxthe222 is offline
Sorry to dig this up, but it was the only post that came up. I have that exact same alternator number that came off a 1979 W72 engine. Same number 1102908 and similar date range. I checked a friend with a W72 TATA as well, it has the same number. Did the last 400's just start getting standardized alternators or something?
Old 02-25-2023, 02:35 PM
wheels wheels is offline
Are these alternators original or replacements?
Old 02-26-2023, 08:06 PM
Thank you for pointing out there may be an error in what I've reported. I found the MVMA's for the 1979 Corvette and Firebird's and don't know what document I used to report what I did 7-8 years ago. I hope this helps...
ID:	607970   Click image for larger version
So long, farewell.
Old 04-23-2023, 06:33 AM
Cool, it sure does. The alternator for the corvette certainly does NOT appear to be 1102908 based on your documentation, and low and behold, under the information for the Pontiac line, under equipped with A/C, the alternator number is 1102908. So, this does appear to be the correct alternator for a 1979 400 W72 engine.
Old 04-23-2023, 10:18 AM
highway star's Avatar
highway star highway star is offline
My 1978 oem alt. has date code 7M19, so what is that date? Didn't they leave out the i when counting months??
Old 04-23-2023, 10:33 AM
Yep, it looks good:
1st digit = year
Letter = month
Last two digits = day
7M19 = Very late 1977 alternator, original for a 1978 T/A!
7 = 1977
M = December (They didn't use "i" to avoid confusion)
19 = 19th
Old 04-23-2023, 10:34 AM
I is left out out on Alts & Starters & on late '66 ('67 model) cast engine parts.
M is December.
Old 04-23-2023, 02:21 PM
Brock1030 Brock1030 is offline
Did some research a couple years back and the number I found for a 1979 W72 is a 63a unit, part number 1105360. Will have to go back and check source…
Old 04-23-2023, 03:23 PM
So, my 1978 W72 alternator is 1102486-61A. Guess the 63A is for more accessories?? Mine just has air conditioner, no power windows or rear defrost.
Old 04-23-2023, 06:25 PM
I posted the 1978 MVMA sheet on the thread you posted on in the past.
https://forums.maxperformanceinc.com...d.php?t=763418
So long, farewell.
Old 05-19-2026, 08:47 PM
Old thread digging through an old box I thought was the original for my 78 180 HP car but it is 1102864. 8E05 so maybe?
